big block--What water pump are you using? #2121592
07/30/16 11:09 PM
07/30/16 11:09 PM
midwest
afx man Offline OP
afx man  Offline OP
midwest
What water pump are people using for B/RB engines? I have a street/strip car and was curious to see the opinions. I was either going to go with the flow-kooler, Milidon (but the impellers look cheap to me on the Milidon) or possibly a marine one with a brass 8 fin impeller. I have seen the comparisons on other sites with various types of water pumps and the brass one seemed to flow good. However the flow-kooler or Milidon were not part of the test group. Do you think the anti-cavitation plate is a gimmick?
Re: big block--What water pump are you using? [Re: afx man] #2121597
07/30/16 11:17 PM
07/30/16 11:17 PM
Kissimmee, Florida
aarlucas Offline
aarlucas  Offline
Kissimmee, Florida
I have been using the same Milodon pump for 13 years with no issues.
Re: big block--What water pump are you using? [Re: afx man] #2121611
07/30/16 11:29 PM
07/30/16 11:29 PM
No, it is highly desired. most all my esp is small blocks but for a BB I would get an 8 blader with the plate or add one & just me I think a parts house pump is plenty adequate
Re: big block--What water pump are you using? [Re: afx man] #2121614
07/30/16 11:32 PM
07/30/16 11:32 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I switched from an Eddy to a Flowcooler last year. Seems to work very well.
Re: big block--What water pump are you using? [Re: afx man] #2121621
07/30/16 11:43 PM
07/30/16 11:43 PM
BlueRacer69 Offline
BlueRacer69  Offline
Flow-Kooler pump has been on my 440 car since 2000. Yes that's 16 yrs now. Still going strong (knock on wood).
Re: big block--What water pump are you using? [Re: afx man] #2121627
07/30/16 11:47 PM
07/30/16 11:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Name brand stock replacement.
Never had an issue, ever.
Don't be the exception.
Re: big block--What water pump are you using? [Re: afx man] #2121724
07/31/16 03:53 AM
07/31/16 03:53 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Original rebuilt
Re: big block--What water pump are you using? [Re: afx man] #2121803
07/31/16 11:18 AM
07/31/16 11:18 AM
Kings Creek, NC
MopeOrNope Offline
MopeOrNope  Offline
Kings Creek, NC
Milodon; zero problems.
Re: big block--What water pump are you using? [Re: MopeOrNope] #2121840
07/31/16 12:13 PM
07/31/16 12:13 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
440 Source Pump. I may switch to the Flowcooler
Abe Lincoln
Re: big block--What water pump are you using? [Re: afx man] #2121863
07/31/16 12:57 PM
07/31/16 12:57 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Napa stock replacement
Re: big block--What water pump are you using? [Re: mikemee1331] #2121931
07/31/16 02:30 PM
07/31/16 02:30 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Same here.. Never a problem....
Re: big block--What water pump are you using? [Re: afx man] #2121950
07/31/16 02:53 PM
07/31/16 02:53 PM
West Central Wisconsin
DeMopuar Offline
DeMopuar  Offline
FlowKooler - worth every penny.
Re: big block--What water pump are you using? [Re: afx man] #2122022
07/31/16 04:59 PM
07/31/16 04:59 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
AutoZone stock replacement with life time warranty, no problems.
Re: big block--What water pump are you using? [Re: afx man] #2122034
07/31/16 05:31 PM
07/31/16 05:31 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
440 source, 512ci AC, 105 outside temps car runs 185 all day.
Re: big block--What water pump are you using? [Re: afx man] #2122035
07/31/16 05:34 PM
07/31/16 05:34 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
I had a FlowKooler on my 440. forgot why i took it off, but when i did, one of the impellers was GONE. never did find it. no BS either. went back to a good old Mopar Performance.
