Re: big block--What water pump are you using?
[Re: afx man]
#2121611
07/30/16 11:29 PM
07/30/16 11:29 PM
RapidRobert
Do you think the anti-cavitation plate is a gimmick? No, it is highly desired. most all my esp is small blocks but for a BB I would get an 8 blader with the plate or add one & just me I think a parts house pump is plenty adequate
[Re: afx man]
#2121627
07/30/16 11:47 PM
07/30/16 11:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Name brand stock replacement.
Never had an issue, ever.
[Re: MopeOrNope]
#2121840
07/31/16 12:13 PM
07/31/16 12:13 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
440 Source Pump. I may switch to the Flowcooler
Abe Lincoln
[Re: afx man]
#2122034
07/31/16 05:31 PM
07/31/16 05:31 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
440 source, 512ci AC, 105 outside temps car runs 185 all day.
[Re: afx man]
#2122035
07/31/16 05:34 PM
07/31/16 05:34 PM
Posts: 863 Pinelands , NJ
joelson6
Pinelands , NJ
I had a FlowKooler on my 440. forgot why i took it off, but when i did, one of the impellers was GONE. never did find it. no BS either. went back to a good old Mopar Performance.
