Fore and aft limiter? #2121367
07/30/16 03:51 PM
07/30/16 03:51 PM
MN
JERICOGTX Offline OP
MN
I need to add a fore and aft limiter on my Road Runner. Can the limiter be installed on the trans/trans mount? Or would it be best mounted on the block?
Jeff
69 GTX 68 Road Runner
Re: Fore and aft limiter? [Re: JERICOGTX] #2121386
07/30/16 04:31 PM
07/30/16 04:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mine goes from the pass side engine mount to the k-member..........
Re: Fore and aft limiter? [Re: JERICOGTX] #2121399
07/30/16 04:55 PM
07/30/16 04:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doesnt mater.. if you use 1 only try to get it as
straight as you can(fore and aft) or run 2 of them
on the trans.. 2 keeps it from pushing sideways
wave
Re: Fore and aft limiter? [Re: JERICOGTX] #2121550
07/30/16 09:55 PM
07/30/16 09:55 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
RB block has that nice ear up front that works nicely. That's where we had it on the Mirada.
Re: Fore and aft limiter? [Re: MR_P_BODY] #2121571
07/30/16 10:31 PM
07/30/16 10:31 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
wave
Good advice
Re: Fore and aft limiter? [Re: JERICOGTX] #2121686
07/31/16 01:28 AM
07/31/16 01:28 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If you are sure there is no flex, just put a solid trans mount on it
Re: Fore and aft limiter? [Re: Monte_Smith] #2121693
07/31/16 01:49 AM
07/31/16 01:49 AM
MN
MN
Flex in the chassis? Can't say for sure it will have zero flex. Jerico said absolutely no solid mount on the trans.
Re: Fore and aft limiter? [Re: JERICOGTX] #2121844
07/31/16 12:22 PM
07/31/16 12:22 PM
gregsdart Offline
gregsdart  Offline
How about using a couple of rod ends? No bind problem then,,,,,,,,,,,
Re: Fore and aft limiter? [Re: JERICOGTX] #2121877
07/31/16 01:17 PM
07/31/16 01:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you running a front and mid plate on your engine
if so dont put a solid trans mount on it... cars flex
and 3 point and the car flexes the first thing to break
is the tail shaft housing... and it will break at the
speedo hole area
wave
Re: Fore and aft limiter? [Re: JERICOGTX] #2121904
07/31/16 01:52 PM
07/31/16 01:52 PM
MN
MN
I am running a front plate, no mid plate. On my GTX, I just used stock type solid mounts and a plate. The RoadRunner has a tubular K member, no factory mounts. The front rails are tied to the cage also.
Re: Fore and aft limiter? [Re: JERICOGTX] #2122478
08/01/16 10:59 AM
08/01/16 10:59 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Can say for sure it will not have zero flex
Boffin Emeritus
Re: Fore and aft limiter? [Re: JERICOGTX] #2122495
08/01/16 11:24 AM
08/01/16 11:24 AM
an8sec70cuda Offline
I just have one fore/aft limiter running from the trans crossmember to the ear at the corner of the pan rail on my 727. Front plate w/ no mid plate and a poly trans mount.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Fore and aft limiter? [Re: an8sec70cuda] #2294078
04/25/17 08:46 PM
04/25/17 08:46 PM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
Any Pictures or problems? been advsed I should use 2 if i go off tranny ears?
Re: Fore and aft limiter? [Re: JERICOGTX] #2294173
04/25/17 11:17 PM
04/25/17 11:17 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
For 20 years I used a front engine plate and a rubber trans mount.I just had installed a midplate and set the engine back a few inches.No limiter,not sure I will need one with a midplate sawzall
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Fore and aft limiter? [Re: JERICOGTX] #2294199
04/25/17 11:55 PM
04/25/17 11:55 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've run these limiters for 4 years with no issue in my 9.0 car. Mid 1.2x 60ft
Doug
Re: Fore and aft limiter? [Re: JERICOGTX] #2294304
04/26/17 02:34 AM
04/26/17 02:34 AM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Motor plates are good for controlling rotational movement. Lousy for controlling aft movement. Stuff moves. I didn't realize how much until I installed a pair and got everything under control. Low 1.20s 60'. Block and trans are a lot of weight. A body at rest tends to stay at rest.
Re: Fore and aft limiter? [Re: dare_dude] #2294406
04/26/17 11:19 AM
04/26/17 11:19 AM
Originally Posted By dare_dude
Any Pictures or problems? been advsed to should use 2 if i go off tranny ears?
Mine looks almost identical to DVW's setup, only I just use one instead of 2. No issues in 11 years w/ a bunch of mid 9 sec passes and a handful of low 9/high 8 sec passes.
CHIP
Re: Fore and aft limiter? [Re: JERICOGTX] #2294413
04/26/17 11:24 AM
04/26/17 11:24 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
tranny ear is where I've had two shifters with the cable mounting point. smile slick looking set up though...
Re: Fore and aft limiter? [Re: J_BODY] #2294438
04/26/17 12:11 PM
04/26/17 12:11 PM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
Gets a little crowded around drivers side ear?
Re: Fore and aft limiter? [Re: dare_dude] #2294595
04/26/17 06:03 PM
04/26/17 06:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I put one on each side at the motor mounts..
it keeps the engine centered.. with just one
you can get by with that.. but since you run
a rubber trans mount the engine and trans might
twist one way.. I tried to eliminate that part
by using one on each side.. works for me with
a 1.19 60'... I do like the dual ones on the
trans ears.. just looks nice
wave
