Fore and aft limiter? #2121367
07/30/16 03:51 PM
07/30/16 03:51 PM
MN
JERICOGTX Offline OP
MN
I need to add a fore and aft limiter on my Road Runner. Can the limiter be installed on the trans/trans mount? Or would it be best mounted on the block?
Jeff
69 GTX 68 Road Runner
Re: Fore and aft limiter? [Re: JERICOGTX] #2121386
07/30/16 04:31 PM
07/30/16 04:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mine goes from the pass side engine mount to the k-member..........
Re: Fore and aft limiter? [Re: JERICOGTX] #2121399
07/30/16 04:55 PM
07/30/16 04:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doesnt mater.. if you use 1 only try to get it as
straight as you can(fore and aft) or run 2 of them
on the trans.. 2 keeps it from pushing sideways
wave
Re: Fore and aft limiter? [Re: JERICOGTX] #2121550
07/30/16 09:55 PM
07/30/16 09:55 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
RB block has that nice ear up front that works nicely. That's where we had it on the Mirada.
Re: Fore and aft limiter? [Re: MR_P_BODY] #2121571
07/30/16 10:31 PM
07/30/16 10:31 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
wave
Good advice
Re: Fore and aft limiter? [Re: JERICOGTX] #2121686
07/31/16 01:28 AM
07/31/16 01:28 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If you are sure there is no flex, just put a solid trans mount on it
Re: Fore and aft limiter? [Re: Monte_Smith] #2121693
07/31/16 01:49 AM
07/31/16 01:49 AM
MN
MN
Flex in the chassis? Can't say for sure it will have zero flex. Jerico said absolutely no solid mount on the trans.
Re: Fore and aft limiter? [Re: JERICOGTX] #2121844
07/31/16 12:22 PM
07/31/16 12:22 PM
gregsdart Offline
gregsdart  Offline
How about using a couple of rod ends? No bind problem then,,,,,,,,,,,
Re: Fore and aft limiter? [Re: JERICOGTX] #2121877
07/31/16 01:17 PM
07/31/16 01:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you running a front and mid plate on your engine
if so dont put a solid trans mount on it... cars flex
and 3 point and the car flexes the first thing to break
is the tail shaft housing... and it will break at the
speedo hole area
wave
Re: Fore and aft limiter? [Re: JERICOGTX] #2121904
07/31/16 01:52 PM
07/31/16 01:52 PM
MN
MN
I am running a front plate, no mid plate. On my GTX, I just used stock type solid mounts and a plate. The RoadRunner has a tubular K member, no factory mounts. The front rails are tied to the cage also.
Re: Fore and aft limiter? [Re: JERICOGTX] #2122478
08/01/16 10:59 AM
08/01/16 10:59 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Can say for sure it will not have zero flex
Boffin Emeritus
Re: Fore and aft limiter? [Re: JERICOGTX] #2122495
08/01/16 11:24 AM
08/01/16 11:24 AM
an8sec70cuda Offline
I just have one fore/aft limiter running from the trans crossmember to the ear at the corner of the pan rail on my 727. Front plate w/ no mid plate and a poly trans mount.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Fore and aft limiter? [Re: an8sec70cuda] #2294078
04/25/17 08:46 PM
04/25/17 08:46 PM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
Any Pictures or problems? been advsed I should use 2 if i go off tranny ears?
Re: Fore and aft limiter? [Re: JERICOGTX] #2294173
04/25/17 11:17 PM
04/25/17 11:17 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
For 20 years I used a front engine plate and a rubber trans mount.I just had installed a midplate and set the engine back a few inches.No limiter,not sure I will need one with a midplate sawzall
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Fore and aft limiter? [Re: JERICOGTX] #2294199
04/25/17 11:55 PM
04/25/17 11:55 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've run these limiters for 4 years with no issue in my 9.0 car. Mid 1.2x 60ft
Doug
Re: Fore and aft limiter? [Re: JERICOGTX] #2294304
04/26/17 02:34 AM
04/26/17 02:34 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Motor plates are good for controlling rotational movement. Lousy for controlling aft movement. Stuff moves. I didn't realize how much until I installed a pair and got everything under control. Low 1.20s 60'. Block and trans are a lot of weight. A body at rest tends to stay at rest.
Re: Fore and aft limiter? [Re: dare_dude] #2294406
04/26/17 11:19 AM
04/26/17 11:19 AM
Originally Posted By dare_dude
Any Pictures or problems? been advsed to should use 2 if i go off tranny ears?
Mine looks almost identical to DVW's setup, only I just use one instead of 2. No issues in 11 years w/ a bunch of mid 9 sec passes and a handful of low 9/high 8 sec passes.
CHIP
Re: Fore and aft limiter? [Re: JERICOGTX] #2294413
04/26/17 11:24 AM
04/26/17 11:24 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
tranny ear is where I've had two shifters with the cable mounting point. smile slick looking set up though...
Re: Fore and aft limiter? [Re: J_BODY] #2294438
04/26/17 12:11 PM
04/26/17 12:11 PM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
Gets a little crowded around drivers side ear?
Re: Fore and aft limiter? [Re: dare_dude] #2294595
04/26/17 06:03 PM
04/26/17 06:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I put one on each side at the motor mounts..
it keeps the engine centered.. with just one
you can get by with that.. but since you run
a rubber trans mount the engine and trans might
twist one way.. I tried to eliminate that part
by using one on each side.. works for me with
a 1.19 60'... I do like the dual ones on the
trans ears.. just looks nice
wave
