Fore and aft limiter?
#2121367
07/30/16 03:51 PM
07/30/16 03:51 PM
Posts: 10,032 MN
JERICOGTX
MN
I need to add a fore and aft limiter on my Road Runner. Can the limiter be installed on the trans/trans mount? Or would it be best mounted on the block?
Jeff
69 GTX
68 Road Runner
Re: Fore and aft limiter?
[Re: JERICOGTX]
#2121386
07/30/16 04:31 PM
07/30/16 04:31 PM
Thumperdart
State of confusion
Mine goes from the pass side engine mount to the k-member..........
[Re: JERICOGTX]
#2121399
07/30/16 04:55 PM
07/30/16 04:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Doesnt mater.. if you use 1 only try to get it as straight as you can(fore and aft) or run 2 of them on the trans.. 2 keeps it from pushing sideways
[Re: MR_P_BODY]
#2121571
07/30/16 10:31 PM
07/30/16 10:31 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Doesnt mater.. if you use 1 only try to get it as straight as you can(fore and aft) or run 2 of them on the trans.. 2 keeps it from pushing sideways Good advice
[Re: Monte_Smith]
#2121693
07/31/16 01:49 AM
07/31/16 01:49 AM
Posts: 10,032 MN
JERICOGTX
MN
If you are sure there is no flex, just put a solid trans mount on it Flex in the chassis? Can't say for sure it will have zero flex. Jerico said absolutely no solid mount on the trans.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2121844
07/31/16 12:22 PM
07/31/16 12:22 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you are sure there is no flex, just put a solid trans mount on it Flex in the chassis? Can't say for sure it will have zero flex. Jerico said absolutely no solid mount on the trans. How about using a couple of rod ends? No bind problem then,,,,,,,,,,,
[Re: JERICOGTX]
#2121877
07/31/16 01:17 PM
07/31/16 01:17 PM
MR_P_BODY
Are you running a front and mid plate on your engine if so dont put a solid trans mount on it... cars flex and 3 point and the car flexes the first thing to break is the tail shaft housing... and it will break at the speedo hole area
[Re: JERICOGTX]
#2121904
07/31/16 01:52 PM
07/31/16 01:52 PM
Posts: 10,032 MN
JERICOGTX
MN
I am running a front plate, no mid plate. On my GTX, I just used stock type solid mounts and a plate. The RoadRunner has a tubular K member, no factory mounts. The front rails are tied to the cage also.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2122478
08/01/16 10:59 AM
08/01/16 10:59 AM
Posts: 4,209 New York
polyspheric
New York
Can say for sure it will not have zero flex
Boffin Emeritus
[Re: JERICOGTX]
#2122495
08/01/16 11:24 AM
08/01/16 11:24 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I just have one fore/aft limiter running from the trans crossmember to the ear at the corner of the pan rail on my 727. Front plate w/ no mid plate and a poly trans mount.
[Re: an8sec70cuda]
#2294078
04/25/17 08:46 PM
04/25/17 08:46 PM
Posts: 567 Sth.IL
dare_dude
Sth.IL
Any Pictures or problems? been advsed I should use 2 if i go off tranny ears?
[Re: JERICOGTX]
#2294304
04/26/17 02:34 AM
04/26/17 02:34 AM
Posts: 11,607 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Motor plates are good for controlling rotational movement. Lousy for controlling aft movement. Stuff moves. I didn't realize how much until I installed a pair and got everything under control. Low 1.20s 60'. Block and trans are a lot of weight. A body at rest tends to stay at rest.
[Re: dare_dude]
#2294406
04/26/17 11:19 AM
04/26/17 11:19 AM
an8sec70cuda
Any Pictures or problems? been advsed to should use 2 if i go off tranny ears? Mine looks almost identical to DVW's setup, only I just use one instead of 2. No issues in 11 years w/ a bunch of mid 9 sec passes and a handful of low 9/high 8 sec passes.
[Re: dare_dude]
#2294595
04/26/17 06:03 PM
04/26/17 06:03 PM
MR_P_BODY
I put one on each side at the motor mounts.. it keeps the engine centered.. with just one you can get by with that.. but since you run a rubber trans mount the engine and trans might twist one way.. I tried to eliminate that part by using one on each side.. works for me with a 1.19 60'... I do like the dual ones on the trans ears.. just looks nice
