fitech installo #2116966
07/25/16 12:27 AM
07/25/16 12:27 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
HI all,
I was wondering if anyone has installed one of those new Fitech efi setups on their car? I was curious how the plumbing went from the fuel pump up? I run a mechanical pump on my 440 and was curious if I needed to upgrade or do anything, or was it plug and play?
thanks
Mikey
1969 Dodge Dart Swinger
Re: fitech installo [Re: MikeyT] #2116975
07/25/16 12:36 AM
07/25/16 12:36 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you are asking can you just use your mechanical pump, then no.
Don't be the exception.
Re: fitech installo [Re: MikeyT] #2116993
07/25/16 12:50 AM
07/25/16 12:50 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
damn...
Re: fitech installo [Re: MikeyT] #2117038
07/25/16 02:40 AM
07/25/16 02:40 AM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
I heard that if you use their "Fuel Command Center" that you can use your mechanical pump.
The mechanical pump feeds the fuel command center that boosts the pressure to work with the throttle bodies.
It raises the price of the system install accordingly though.
Re: fitech installo [Re: MikeyT] #2117044
07/25/16 03:00 AM
07/25/16 03:00 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
You can you use stock mechanical fuel pump no problem, just before the line gets to the throttle ody you need to fit a large sump somewhere that will run the final line to the throttlebody/carb. Also will need a return line is all.
Look up their fuel command center. Buy from Paceperformance to save maybe 5% ifrc?
Once I get back from the Nats that will be my next large project for the bee.
Re: fitech installo [Re: MikeyT] #2117066
07/25/16 04:32 AM
07/25/16 04:32 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Just Got the FiTech Friday, but I will be using an EFI tank mounted pump.
You can use a surge tank that is filled by the stock low pressure pump, then there is a high pressure EFI pump inside the tank to supply the EFI.
This could even be setup to not use a return line, but the return helps lower the fuel temperature.
Re: fitech installo [Re: 451Mopar] #2117085
07/25/16 06:05 AM
07/25/16 06:05 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
When I talked to FiTech they told me that the supposed "advertised" vent on the Command center "is a RETURN" and "NOT" a vent. Said there was an advertising mess-up on calling it a vent. This was why some are having fuel puking out their vent.
So I asked if the 440 & hemi cars 1/4" return line would be big enough to handle the return from the Command center. Don't remember his exact quote but it was a negative.
Re: fitech installo [Re: MikeyT] #2117182
07/25/16 11:25 AM
07/25/16 11:25 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
I never understood why the didn't fit a float into the fuel command center? every carb I've ever worked on had a float to shut off fuel flow from a low pressure pump.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: fitech installo [Re: MikeyT] #2117343
07/25/16 03:03 PM
07/25/16 03:03 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
thanks guys this is extremely helpful!
Devin, are you running the Bee to the nats this year?
Mikey
Re: fitech installo [Re: MikeyT] #2117475
07/25/16 06:05 PM
07/25/16 06:05 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Return lines are usually the same size as the feed line - I suspect because of the volume that's not used at low rpms.
Re: fitech installo [Re: MikeyT] #2117634
07/25/16 09:58 PM
07/25/16 09:58 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Mikey
Plan is trailer the Bee there and possibly have someone drive my challenger. The Challenger I will be attempting to sell, but will also use in the stick class if I don't have my super bee squared away and comfortable racing it.
Re: fitech installo [Re: Stanton] #2117752
07/25/16 11:35 PM
07/25/16 11:35 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
My thinking behind the question I asked FiTech on the 1/4 return line was,... would the pwm controlling of the pump at slow and low cruz speed be enough to where the 1/4 return would work? But the conversation never quit got that far, he didn't like that small a return.
Any of you guys think the 1/4 return would work with the pump speed reduced?
PS: Just got a return call from a friend who thinks the 1/4 return would work with the reduced pump speed. Not sure at the moment which way I'll go, but if I did, my lines are stainless and would require farrows to work. Probably easier to just run a correct size hose and be done. Just keep try'n to stay with the factory appearing look.
Re: fitech installo [Re: MikeyT] #2117764
07/25/16 11:48 PM
07/25/16 11:48 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Ok maybe a noob question but was is the worst that can happen if you run the normal 1/4" return line?
Mikey
PS... Where are all the " throw a Holley on it and be done with it!" Guys?
Mikey
Re: fitech installo [Re: MikeyT] #2117785
07/26/16 12:09 AM
07/26/16 12:09 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I thought pumps were constant velocity to maintain the pressure required by the injectors. If the pump slows down then when the injectors open less fuel will flow through them which the O2 sensor says is "lean" so it holds the injectors open longer OR increases pump speed/pressure OR the built in regulator closes.
I thought the FiTech incorporated the regulator in the TB.
Anyhow, I'd probably go with what the manufacturer suggests - it increases the likelyhood of the unit working properly!
Re: fitech installo [Re: MikeyT] #2117830
07/26/16 01:05 AM
07/26/16 01:05 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I stepped down from a -10 feed for the carbs to a -8 which splits into -6 to the TB's, I made the return lines all -6. It idles great, is nice and crisp. Reading the literature it suggested running the power through the FITech computer to the in-tank pump. The way I read it the computer will control voltage to the fuel pump to help regulate the pressure.
The Fuel command centre would be nice if you don't want an in-tank pump I suppose, I can't see any reason not to run an in-tank pump though.
Sheldon
Sheldon
Re: fitech installo [Re: RUNCHARGER] #2118011
07/26/16 11:56 AM
07/26/16 11:56 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Sheldon
Hey looks good !
Not to hijack, but just wondering what your 572 combo specs out like and hows it go in the car with the FiTech ?
wink
smile
Re: fitech installo [Re: LAD 524] #2118191
07/26/16 04:36 PM
07/26/16 04:36 PM
near Kansas City
igozumn Offline
igozumn  Offline
near Kansas City
I ditched the original 1/4 return line on my '69, used the original 5/16 supply as the new return, and installed a reproduction 3/8 supply. Fitech advised me that the 5/16 would suffice.
