fitech installo
#2116966
07/25/16 12:27 AM
07/25/16 12:27 AM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
HI all,
I was wondering if anyone has installed one of those new Fitech efi setups on their car? I was curious how the plumbing went from the fuel pump up? I run a mechanical pump on my 440 and was curious if I needed to upgrade or do anything, or was it plug and play?
thanks
Mikey
1969 Dodge Dart Swinger
Re: fitech installo
[Re: MikeyT]
#2116975
07/25/16 12:36 AM
07/25/16 12:36 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If you are asking can you just use your mechanical pump, then no.
Re: fitech installo
[Re: MikeyT]
#2117343
07/25/16 03:03 PM
07/25/16 03:03 PM
MikeyT
Watertown, WI
thanks guys this is extremely helpful!
Devin, are you running the Bee to the nats this year?
Mikey
Re: fitech installo
[Re: MikeyT]
#2117634
07/25/16 09:58 PM
07/25/16 09:58 PM
Posts: 6,445 Missouri
68KillerBee
Missouri
Mikey Plan is trailer the Bee there and possibly have someone drive my challenger. The Challenger I will be attempting to sell, but will also use in the stick class if I don't have my super bee squared away and comfortable racing it.
Re: fitech installo
[Re: Stanton]
#2117752
07/25/16 11:35 PM
07/25/16 11:35 PM
Posts: 1,805 ky hills
thehemikid
ky hills
Return lines are usually the same size as the feed line - I suspect because of the volume that's not used at low rpms. My thinking behind the question I asked FiTech on the 1/4 return line was,... would the pwm controlling of the pump at slow and low cruz speed be enough to where the 1/4 return would work? But the conversation never quit got that far, he didn't like that small a return. Any of you guys think the 1/4 return would work with the pump speed reduced? PS: Just got a return call from a friend who thinks the 1/4 return would work with the reduced pump speed. Not sure at the moment which way I'll go, but if I did, my lines are stainless and would require farrows to work. Probably easier to just run a correct size hose and be done. Just keep try'n to stay with the factory appearing look.
Re: fitech installo
[Re: MikeyT]
#2117764
07/25/16 11:48 PM
07/25/16 11:48 PM
MikeyT
Watertown, WI
Ok maybe a noob question but was is the worst that can happen if you run the normal 1/4" return line?
Mikey
PS... Where are all the " throw a Holley on it and be done with it!" Guys?
Mikey
Re: fitech installo
[Re: MikeyT]
#2117830
07/26/16 01:05 AM
07/26/16 01:05 AM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
I stepped down from a -10 feed for the carbs to a -8 which splits into -6 to the TB's, I made the return lines all -6. It idles great, is nice and crisp. Reading the literature it suggested running the power through the FITech computer to the in-tank pump. The way I read it the computer will control voltage to the fuel pump to help regulate the pressure. The Fuel command centre would be nice if you don't want an in-tank pump I suppose, I can't see any reason not to run an in-tank pump though.
Sheldon
Sheldon
Re: fitech installo
[Re: RUNCHARGER]
#2118011
07/26/16 11:56 AM
07/26/16 11:56 AM
Posts: 620 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Sheldon '' Hey looks good ! Not to hijack, but just wondering what your 572 combo specs out like and hows it go in the car with the FiTech ?
