Meziere flexplate with BB and Glide...? #2116810
07/24/16 08:31 PM
07/24/16 08:31 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
So I broke another JW "the wheel" flexplates yesterday. It only had 82 passes on it and was brand new last fall! It broke at the stripe. I heard a snap and instant smoke in the car. After I got stopped safely I noticed a tore tranny cooler line. which pumped fluid all over the header. Once I got it back to the pits I found two large pieces of ring gear in my belly pan. I'm fairly certain the starter was not hung up. My wife helps me in the burnout box and is at the starting line so I'm sure her or myself would have heard that.
I ordered a Meziere billet flexplate part number FP30608. Has anyone ran this plate behind a BB mopar with a JW ultra bell hooked to a glide?
Anything else I need to make this work? I want to have it fixed in time to leave town again next thurday...
Re: Meziere flexplate with BB and Glide...? [Re: Forest] #2116889
07/24/16 10:44 PM
07/24/16 10:44 PM
I haven't used any of the Mezieres flexplates. I'm sorry you had that problem, I'm really glad you didn't get hurt or damage the car more thumbs
BTW, is it a 6 bolt or 8 bolt crankshaft?
Re: Meziere flexplate with BB and Glide...? [Re: Forest] #2116897
07/24/16 10:55 PM
07/24/16 10:55 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I just switched to a Meziere flexplate and a turbo 400 with a JW Ultrabell, no issues at all. Just make sure you get starter alignment correct.
Re: Meziere flexplate with BB and Glide...? [Re: Sammy] #2116980
07/25/16 12:38 AM
07/25/16 12:38 AM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Any advice on starter alignment? With the JW ultra bell all you can do is shim in and out correct? I think I will order a Meziere starter tonight from Summit. They have them in stock.
Yes Cab could have been a lot worse! Luckily it was at the finish line so I was already off the gas and pulling the chute...
Oh yea its 8 bolt
Re: Meziere flexplate with BB and Glide...? [Re: Forest] #2117041
07/25/16 02:46 AM
07/25/16 02:46 AM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Re: Meziere flexplate with BB and Glide...? [Re: Forest] #2117048
07/25/16 03:18 AM
07/25/16 03:18 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
Don't have any info but just wanted to say it was nice to see you guys!! BTW I got down to the last ten cars in pro.. See ya next time
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Meziere flexplate with BB and Glide...? [Re: Stroker Scamp] #2117124
07/25/16 09:56 AM
07/25/16 09:56 AM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Thanks Mike we enjoyed hanging out too!
Re: Meziere flexplate with BB and Glide...? [Re: Forest] #2117128
07/25/16 10:00 AM
07/25/16 10:00 AM
moparx Offline
moparx  Offline
after seeing the pics, are you going to replace the bell now, or smooth out the "dimples" and replace at the expiration date ? or will it recert after the dimple smoothing ? keep in mind i will never have anything remotely as fast, just seriously contemplating an ultrabell for my humpback project and wondering what something like this event would have on the function of the part itself.
beer
Re: Meziere flexplate with BB and Glide...? [Re: Sammy] #2117597
07/25/16 09:10 PM
07/25/16 09:10 PM
Midwest
fuseable Offline
fuseable  Offline
Midwest
Sammy did that Meziere set up come with a crank adapter with the proper GM converter snout ID ?
Re: Meziere flexplate with BB and Glide...? [Re: fuseable] #2117648
07/25/16 10:04 PM
07/25/16 10:04 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
According to Meziere it does. Just not sure on starter clearance/shimming until I mock it up I guess.
Re: Meziere flexplate with BB and Glide...? [Re: Forest] #2117737
07/25/16 11:12 PM
07/25/16 11:12 PM
Midwest
fuseable Offline
fuseable  Offline
Midwest
I have the JW setup and will be watching this close.
Re: Meziere flexplate with BB and Glide...? [Re: Forest] #2117968
07/26/16 10:47 AM
07/26/16 10:47 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
If you have any questions just call or e-mail Meziere, their customer service is off the chart.
Bill
Re: Meziere flexplate with BB and Glide...? [Re: 340Cuda] #2118058
07/26/16 01:17 PM
07/26/16 01:17 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Bill
Oh I did and they were very helpful, but weren't sure what the flexplate offset will look like until it's mocked up. I should have my parts this evening and I will update everyone on the progress.
