Re: Meziere flexplate with BB and Glide...?
[Re: Forest]
#2116889
07/24/16 10:44 PM
07/24/16 10:44 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
I haven't used any of the Mezieres flexplates. I'm sorry you had that problem, I'm really glad you didn't get hurt or damage the car more BTW, is it a 6 bolt or 8 bolt crankshaft?
[Re: Sammy]
#2116980
07/25/16 12:38 AM
07/25/16 12:38 AM
Posts: 916 SE Washington
Forest
SE Washington
I just switched to a Meziere flexplate and a turbo 400 with a JW Ultrabell, no issues at all. Just make sure you get starter alignment correct. Any advice on starter alignment? With the JW ultra bell all you can do is shim in and out correct? I think I will order a Meziere starter tonight from Summit. They have them in stock. Yes Cab could have been a lot worse! Luckily it was at the finish line so I was already off the gas and pulling the chute... Oh yea its 8 bolt
[Re: Forest]
#2117048
07/25/16 03:18 AM
07/25/16 03:18 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
Don't have any info but just wanted to say it was nice to see you guys!! BTW I got down to the last ten cars in pro.. See ya next time
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Stroker Scamp]
#2117124
07/25/16 09:56 AM
07/25/16 09:56 AM
Forest
SE Washington
Don't have any info but just wanted to say it was nice to see you guys!! BTW I got down to the last ten cars in pro.. See ya next time Thanks Mike we enjoyed hanging out too!
[Re: fuseable]
#2117648
07/25/16 10:04 PM
07/25/16 10:04 PM
Forest
SE Washington
Sammy did that Meziere set up come with a crank adapter with the proper GM converter snout ID ? According to Meziere it does. Just not sure on starter clearance/shimming until I mock it up I guess.
[Re: 340Cuda]
#2118058
07/26/16 01:17 PM
07/26/16 01:17 PM
Forest
SE Washington
If you have any questions just call or e-mail Meziere, their customer service is off the chart.
Bill Oh I did and they were very helpful, but weren't sure what the flexplate offset will look like until it's mocked up. I should have my parts this evening and I will update everyone on the progress.
