Plug Wires #2115441
07/22/16 12:37 PM
07/22/16 12:37 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
Plug Wires
What are you guys buying over the counter to fit a B or RB Block correctly ? Part number and brand ?
With the massive lengths of the general part number wires they always look crappy.
MLR426
Re: Plug Wires [Re: MLR426] #2115449
07/22/16 12:45 PM
07/22/16 12:45 PM
Chicago
PurpleBeeper Offline
Chicago
I run custom-cut Accel 8mm wires...not sure on part number.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Plug Wires [Re: MLR426] #2115450
07/22/16 12:45 PM
07/22/16 12:45 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
over the counter limits your choices but i have heard good things about Autozone's Duralast 8mm universal set. they are 'cut to fit' though if that bothers you.
http://www.autozone.com/ignition-tune-up...95_0_5320_1356/
Re: Plug Wires [Re: MLR426] #2115455
07/22/16 12:52 PM
07/22/16 12:52 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We run Taylors.Have for years on everything.A few are a bit long but not real bad.Even ran a set listed for my 57 Chrysler when I had it.On my 440 and the 413 we run stock 0nes for a 440 and then install the GM type boots for MSD dist.Rocky
Chrysler Firepower
Re: Plug Wires [Re: therocks] #2115481
07/22/16 01:25 PM
07/22/16 01:25 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Do yourself a favor and get the Firecore wires! up
Admiration For Multiple Carburetor Vehicles...
Re: Plug Wires [Re: PurpleBeeper] #2115871
07/22/16 11:13 PM
07/22/16 11:13 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have yet to find a set that will even fit a stock application correctly without being too long or short. Therefor, we make every set for the specific application. twocents
Re: Plug Wires [Re: TJP] #2115879
07/22/16 11:18 PM
07/22/16 11:18 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
https://www.summitracing.com/oh/parts/sum-889004/overview/make/dodge
Nice set for the price and comparable to the pick of this board.
Re: Plug Wires [Re: MLR426] #2115891
07/22/16 11:29 PM
07/22/16 11:29 PM
what about sliding the terminal/wire back out of the boot then opening the crimp a bit then cutting the wire leaving a core pigtail & folding it under the terminal and recrimping. easy to do & some lube on the insulation helps greatly with this when reinstalling & most wire crimpers have a pair of notch halves sized just for crimping these terminals
Re: Plug Wires [Re: PurpleBeeper] #2115967
07/23/16 03:13 AM
07/23/16 03:13 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Me 2
I have mechanical Aptitude.
I can screw up anything.
Re: Plug Wires [Re: RapidRobert] #2116047
07/23/16 11:27 AM
07/23/16 11:27 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Yep, this is what I do, too. And it helps to have some spare wires (old or new) so that you can use the mix of straights and 90*s on the cap ends that works the best.
Master, again and still
Re: Plug Wires [Re: DaveRS23] #2116086
07/23/16 12:25 PM
07/23/16 12:25 PM
Agreed, gives you a spot on perfect match
Re: Plug Wires [Re: MLR426] #2117158
07/25/16 10:56 AM
07/25/16 10:56 AM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
I have always done the re-cut and crimping of wires. I thought it was worth asking if someone explored other part numbers for better fitment without re-doing the wires.
MLR426
Re: Plug Wires [Re: MLR426] #2117793
07/26/16 12:18 AM
07/26/16 12:18 AM
definitely worth asking & you'd think with routing being pretty much std (I think) with a few model variations maybe that they'd get em closer or if that ain't possible (too many possibilities) that they'd stick with cut to fit kits. I'd guess that if the wires wont reach on an app that there'd be too many potential comebacks. bad feedback is a killer
Re: Plug Wires [Re: MLR426] #2118809
07/27/16 02:36 AM
07/27/16 02:36 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I will say my Firecore wires were sent to me and all I told them was its a 440. They came with 45 degree angle on all the wires and I must say the lenth was just right and they fit great with my TTI headers. I mean they really fit just right and I do like them. I have used Taylor and Moroso wires also which fit ok but I feel the Firecore are a step better IMO. Ron
