Re: Plug Wires
[Re: MLR426]
#2115449
07/22/16 12:45 PM
07/22/16 12:45 PM
Posts: 956 Chicago
PurpleBeeper
Chicago
I run custom-cut Accel 8mm wires...not sure on part number.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
Re: Plug Wires
[Re: MLR426]
#2115455
07/22/16 12:52 PM
07/22/16 12:52 PM
Posts: 21,067 Niles , Ohio
therocks
Niles , Ohio
We run Taylors.Have for years on everything.A few are a bit long but not real bad.Even ran a set listed for my 57 Chrysler when I had it.On my 440 and the 413 we run stock 0nes for a 440 and then install the GM type boots for MSD dist.Rocky
Chrysler Firepower
Re: Plug Wires
[Re: MLR426]
#2115891
07/22/16 11:29 PM
07/22/16 11:29 PM
RapidRobert
With the massive lengths of the general part number wires they always look crappy. what about sliding the terminal/wire back out of the boot then opening the crimp a bit then cutting the wire leaving a core pigtail & folding it under the terminal and recrimping. easy to do & some lube on the insulation helps greatly with this when reinstalling & most wire crimpers have a pair of notch halves sized just for crimping these terminals
Re: Plug Wires
[Re: RapidRobert]
#2116047
07/23/16 11:27 AM
07/23/16 11:27 AM
Posts: 12,058 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
With the massive lengths of the general part number wires they always look crappy. what about sliding the terminal/wire back out of the boot then opening the crimp a bit then cutting the wire leaving a core pigtail & folding it under the terminal and recrimping. easy to do & some lube on the insulation helps greatly with this when reinstalling & most wire crimpers have a pair of notch halves sized just for crimping these terminals Yep, this is what I do, too. And it helps to have some spare wires (old or new) so that you can use the mix of straights and 90*s on the cap ends that works the best.
Master, again and still
Re: Plug Wires
[Re: DaveRS23]
#2116086
07/23/16 12:25 PM
07/23/16 12:25 PM
RapidRobert
And it helps to have some spare wires (old or new) so that you can use the mix of straights and 90*s on the cap ends that works the best. Agreed, gives you a spot on perfect match
Re: Plug Wires
[Re: MLR426]
#2117793
07/26/16 12:18 AM
07/26/16 12:18 AM
RapidRobert
I thought it was worth asking if someone explored other part numbers for better fitment without re-doing the wires. definitely worth asking & you'd think with routing being pretty much std (I think) with a few model variations maybe that they'd get em closer or if that ain't possible (too many possibilities) that they'd stick with cut to fit kits. I'd guess that if the wires wont reach on an app that there'd be too many potential comebacks. bad feedback is a killer
