WINDOW NET WITH A SWINGOUT #2115039
07/21/16 07:14 PM
07/21/16 07:14 PM
fresno ca
mikeysmopars Offline OP
fresno ca
I know this has been on here before but what mounting kit and window net are you guys using with a swing out bar?
Anyone with pix? Any fancy mounting hardware?
I looked through summit and none specific for swing out.
Thanks in advance.
Mike
Founder and CEO of the Central Valley Mopar Drag Pack
Re: WINDOW NET WITH A SWINGOUT [Re: mikeysmopars] #2115049
07/21/16 07:42 PM
07/21/16 07:42 PM
tboomer Offline
tboomer  Offline
Mike...My 64 isn't at my home but I think my stuff is Alston.
Re: WINDOW NET WITH A SWINGOUT [Re: tboomer] #2115052
07/21/16 07:49 PM
07/21/16 07:49 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
http://www.swracecars.com/store/Window-Net-Mounting-Kit-OSCARItem_315=75-370.aspx
Something like this with a cable is the only way I can think to use a window net and a door bar swing-out.
Re: WINDOW NET WITH A SWINGOUT [Re: mikeysmopars] #2115065
07/21/16 08:22 PM
07/21/16 08:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use RJS Racing Equipment for the net(make sure you
use the ribbon style.. you dont have to recert it)..
they also have a hinged mount for it.... they also
make custom size nets.. just send them a template
http://businessfinder.mlive.com/rjs-racing-equipment-inc-hazel-park-mi.html
wave
Re: WINDOW NET WITH A SWINGOUT [Re: MR_P_BODY] #2115073
07/21/16 08:36 PM
07/21/16 08:36 PM
fresno ca
fresno ca
Thanks Guys, Both links were helpful, Also didn't know the ribbon style net did not have to be recerted. thumbs
Re: WINDOW NET WITH A SWINGOUT [Re: mikeysmopars] #2117152
07/25/16 10:41 AM
07/25/16 10:41 AM
an8sec70cuda Offline
I have an Alston's chassis works kit in my cuda. 10 pt. cage w/ swing outs and window net. Has a cable that attaches the front lower portion of the net down to the rocker bar. Rear lower is bolted to the main hoop. Top rear slides into a loop and then a pin attaches the top front. Don't think I have any pics of it on this PC or my phone.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: WINDOW NET WITH A SWINGOUT [Re: an8sec70cuda] #2117268
07/25/16 01:30 PM
07/25/16 01:30 PM
fresno ca
fresno ca
I would like to see a picture of that, I have the same Alston kit!
Re: WINDOW NET WITH A SWINGOUT [Re: mikeysmopars] #2117334
07/25/16 02:56 PM
07/25/16 02:56 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine swings in or out. It is attached at the cage down tune with tabs & then attached at the top with the factory Chrysler flip seat belt buckle.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: WINDOW NET WITH A SWINGOUT [Re: 6PKRTSE] #2117335
07/25/16 02:57 PM
07/25/16 02:57 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Found a better picture from inside.
Re: WINDOW NET WITH A SWINGOUT [Re: 6PKRTSE] #2117340
07/25/16 03:01 PM
07/25/16 03:01 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Oops, sorry, I misread the post. Obviously, my bars are not swing out bars. I was thinking just a swing out net when I first read the post.
Re: WINDOW NET WITH A SWINGOUT [Re: 6PKRTSE] #2133278
08/15/16 04:12 AM
08/15/16 04:12 AM
fresno ca
fresno ca
Here is what a came up with,i mounted the ends in heims so it drops right along side the seat and used a bicycle cable that is pre coyled and anchored to the floor.it easily swings up and down and latches. The top bolt is barely flush with roll bar so it is all inside the cage.this look like it will go through tech Alright?
IMG_20160814_174558939-640x480.jpgIMG_20160814_174524012-640x480.jpgIMG_20160814_174535425-640x480.jpg
Re: WINDOW NET WITH A SWINGOUT [Re: mikeysmopars] #2133279
08/15/16 04:13 AM
08/15/16 04:13 AM
fresno ca
fresno ca
Latch
Re: WINDOW NET WITH A SWINGOUT [Re: mikeysmopars] #2133305
08/15/16 08:13 AM
08/15/16 08:13 AM
mack Offline
mack  Offline
I'm not sure about that cable. I have mine fastened at the top same as you. My back bottom is attached to the main hoop also. I should have a picture of mine during construction of mine. I do not have it on my phone. I am already at the airport but let me lookin my computer and see if I have the photo there. Will upload when I get to my hotel tonite.
Mack Reeves SST 2377 FS/D 2377
Re: WINDOW NET WITH A SWINGOUT [Re: mikeysmopars] #2133617
08/15/16 04:16 PM
08/15/16 04:16 PM
mack Offline
mack  Offline
Let's see if this works...
file:///C:/Users/reeves.ma/Pictures/Building%20a%20DP%20Challenger/Mine/InterionReinstall.jpg
Re: WINDOW NET WITH A SWINGOUT [Re: mikeysmopars] #2133620
08/15/16 04:21 PM
08/15/16 04:21 PM
mack Offline
mack  Offline
Try the link... I have a complete file on the build on PhotoBucket the picture or there are several actually... I will share that so you can look and see how mine is done. Not saying your cable won't work but this will pass NHRA tech... Link to my photobucket account to follow....
Re: WINDOW NET WITH A SWINGOUT [Re: mikeysmopars] #2133635
08/15/16 04:33 PM
08/15/16 04:33 PM
mack Offline
mack  Offline
Here is the link... Sorry for all the trouble but I'm not a IT person and know enough about computers to be dangerous....
http://s882.photobucket.com/user/mreeves...rt=2&page=1
Re: WINDOW NET WITH A SWINGOUT [Re: mack] #2133664
08/15/16 05:07 PM
08/15/16 05:07 PM
fresno ca
fresno ca
Mack, first of all thanks for the pictures,and Damn your ambitious! Hell of a nice car! I do like how you mounted your net. I'm going to see if it will fly as is for now but I can see the way yours is would pass easyily.i saved the a bunch of you pictures, thanks for sharing!
Re: WINDOW NET WITH A SWINGOUT [Re: mack] #2133687
08/15/16 06:02 PM
08/15/16 06:02 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Re: WINDOW NET WITH A SWINGOUT [Re: mikeysmopars] #2133806
08/15/16 08:28 PM
08/15/16 08:28 PM
mack Offline
mack  Offline
How do you do that???
Re: WINDOW NET WITH A SWINGOUT [Re: mack] #2133839
08/15/16 08:59 PM
08/15/16 08:59 PM
Renton Washington
Triple Threat Offline
Renton Washington
Take the picture address, and put this around it
[img] PICTUREADDRESS.com [/img]
But with no spaces. Photobucket has these codes already built for you on the website, just navigate to the picture and the codes are on the right hand side. Choose the top one, and past the [img] code around it.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
