WINDOW NET WITH A SWINGOUT
#2115039
07/21/16 07:14 PM
07/21/16 07:14 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
I know this has been on here before but what mounting kit and window net are you guys using with a swing out bar? Anyone with pix? Any fancy mounting hardware? I looked through summit and none specific for swing out. Thanks in advance. Mike
Founder and CEO of the Central Valley Mopar Drag Pack
Re: WINDOW NET WITH A SWINGOUT
[Re: mikeysmopars]
#2117152
07/25/16 10:41 AM
07/25/16 10:41 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I have an Alston's chassis works kit in my cuda. 10 pt. cage w/ swing outs and window net. Has a cable that attaches the front lower portion of the net down to the rocker bar. Rear lower is bolted to the main hoop. Top rear slides into a loop and then a pin attaches the top front. Don't think I have any pics of it on this PC or my phone.
[Re: an8sec70cuda]
#2117268
07/25/16 01:30 PM
07/25/16 01:30 PM
mikeysmopars
fresno ca
I have an Alston's chassis works kit in my cuda. 10 pt. cage w/ swing outs and window net. Has a cable that attaches the front lower portion of the net down to the rocker bar. Rear lower is bolted to the main hoop. Top rear slides into a loop and then a pin attaches the top front. Don't think I have any pics of it on this PC or my phone. I would like to see a picture of that, I have the same Alston kit!
[Re: mikeysmopars]
#2117334
07/25/16 02:56 PM
07/25/16 02:56 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
Mine swings in or out. It is attached at the cage down tune with tabs & then attached at the top with the factory Chrysler flip seat belt buckle.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2117335
07/25/16 02:57 PM
07/25/16 02:57 PM
6PKRTSE
Motor City
Found a better picture from inside.
[Re: 6PKRTSE]
#2117340
07/25/16 03:01 PM
07/25/16 03:01 PM
6PKRTSE
Motor City
Oops, sorry, I misread the post. Obviously, my bars are not swing out bars. I was thinking just a swing out net when I first read the post.
[Re: 6PKRTSE]
#2133278
08/15/16 04:12 AM
08/15/16 04:12 AM
mikeysmopars
fresno ca
Here is what a came up with,i mounted the ends in heims so it drops right along side the seat and used a bicycle cable that is pre coyled and anchored to the floor.it easily swings up and down and latches. The top bolt is barely flush with roll bar so it is all inside the cage.this look like it will go through tech Alright?
[Re: mikeysmopars]
#2133305
08/15/16 08:13 AM
08/15/16 08:13 AM
Posts: 116 Florida
mack
I'm not sure about that cable. I have mine fastened at the top same as you. My back bottom is attached to the main hoop also. I should have a picture of mine during construction of mine. I do not have it on my phone. I am already at the airport but let me lookin my computer and see if I have the photo there. Will upload when I get to my hotel tonite.
Mack Reeves
SST 2377
FS/D 2377
[Re: mikeysmopars]
#2133617
08/15/16 04:16 PM
08/15/16 04:16 PM
Posts: 116 Florida
mack
Let's see if this works...
file:///C:/Users/reeves.ma/Pictures/Building%20a%20DP%20Challenger/Mine/InterionReinstall.jpg
Mack Reeves
SST 2377
FS/D 2377
[Re: mikeysmopars]
#2133620
08/15/16 04:21 PM
08/15/16 04:21 PM
Posts: 116 Florida
mack
Try the link... I have a complete file on the build on PhotoBucket the picture or there are several actually... I will share that so you can look and see how mine is done. Not saying your cable won't work but this will pass NHRA tech... Link to my photobucket account to follow....
Mack Reeves
SST 2377
FS/D 2377
[Re: mack]
#2133664
08/15/16 05:07 PM
08/15/16 05:07 PM
mikeysmopars
fresno ca
Mack, first of all thanks for the pictures,and Damn your ambitious! Hell of a nice car! I do like how you mounted your net. I'm going to see if it will fly as is for now but I can see the way yours is would pass easyily.i saved the a bunch of you pictures, thanks for sharing!
[Re: mack]
#2133839
08/15/16 08:59 PM
08/15/16 08:59 PM
Triple Threat
Renton Washington
Take the picture address, and put this around it [img] PICTUREADDRESS.com [/img] But with no spaces. Photobucket has these codes already built for you on the website, just navigate to the picture and the codes are on the right hand side. Choose the top one, and past the [img] code around it.
