Re: Overheating issues
[Re: ROADRCR]
#2112905
07/18/16 11:32 PM
07/18/16 11:32 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
16 inch electric fan on outside of radiator on a shroud pulling air from engine compartment
That is your problem. You are trying to pull air out of the engine compartment with a fan on the outside.
You need to put the fan inside and pull air INTO the engine compartment.
[Re: Supercuda]
#2112912
07/18/16 11:35 PM
07/18/16 11:35 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
You need to put the fan inside and pull air INTO the engine compartment. x2
[Re: poorboy]
#2112963
07/19/16 12:26 AM
07/19/16 12:26 AM
RapidRobert
I would suggest a 7 blade rigid fan with a MP thermal clutch fan spaced halfway into a fairly wide schroud. other than that I am assuming your timing/mixture/pulley ratio are in the ballpark
[Re: ROADRCR]
#2113066
07/19/16 08:35 AM
07/19/16 08:35 AM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Personally, I'm not a big fan of "pusher" fans. I much prefer "puller" type unless you are extremely space-limited.
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: ROADRCR]
#2113527
07/19/16 08:13 PM
07/19/16 08:13 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
A pusher fan in a shroud which is covering much of the radiator will NOT be as effective as a pusher without the shroud. If you're going to stick with a pusher then remove the shroud... otherwise put the fan on the engine side of the radiator with the shroud like it should have been done in the beginning.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
