Overheating issues #2112900
07/18/16 11:29 PM
07/18/16 11:29 PM
ROADRCR Offline OP
ROADRCR  Offline OP
Situation:
416 stroker small block, 458 hp on dyno, aluminum heads, headers. 190 degree thermostat, Mezeire electric water pump, 26 inch Be Cool aluminum radiator, 50/50 antifreeze mix. Less than 100 miles on motor, 16 inch electric fan on outside of radiator on a shroud pulling air from engine compartment.
Took it out for a run Sunday, ambient temperature 96 degrees and within 20 minutes temperature gauge went to 210 and stayed for a while then started to creep up. Thinking the following:
-Engine still a little tight should wait for a while for things to loosen up.
-with just a 16 inch opening for the fan and the shroud covering most of the radiator I made a mistake and should have used twin fan set up or remove shroud and stick with 16 inch fan. Car ran great back in January with no overheating, Switch to EVANS cooling solution? Any help greatly appreciated Thank you!
Re: Overheating issues [Re: ROADRCR] #2112905
07/18/16 11:32 PM
07/18/16 11:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That is your problem. You are trying to pull air out of the engine compartment with a fan on the outside.
You need to put the fan inside and pull air INTO the engine compartment.
Don't be the exception.
Re: Overheating issues [Re: Supercuda] #2112912
07/18/16 11:35 PM
07/18/16 11:35 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
x2
Re: Overheating issues [Re: ROADRCR] #2112937
07/18/16 11:57 PM
07/18/16 11:57 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Or have the fan outside the radiator PUSH the air through the radiator and into the engine compartment.
The natural flow of air hitting the front of the vehicle as it moves forward is to pass through the radiator and into the engine compartment. If you are trying to pull the air forward through the radiator, it is meeting the air that is naturally flowing in the other direction. The result is the radiator is probably not seeing any or almost no air flow as the vehicle moves forward. Its a wonder it stayed that cool for that long! Gene
Re: Overheating issues [Re: poorboy] #2112963
07/19/16 12:26 AM
07/19/16 12:26 AM
I would suggest a 7 blade rigid fan with a MP thermal clutch fan spaced halfway into a fairly wide schroud. other than that I am assuming your timing/mixture/pulley ratio are in the ballpark
Re: Overheating issues [Re: Supercuda] #2113060
07/19/16 08:02 AM
07/19/16 08:02 AM
ROADRCR Offline OP
ROADRCR  Offline OP
Yep, I just realized after my post what I did. Duh! I will reverse the airflow and try it the correct way.Thanks for pointing that out!
Re: Overheating issues [Re: ROADRCR] #2113066
07/19/16 08:35 AM
07/19/16 08:35 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Personally, I'm not a big fan of "pusher" fans. I much prefer "puller" type unless you are extremely space-limited.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Overheating issues [Re: ROADRCR] #2113072
07/19/16 09:01 AM
07/19/16 09:01 AM
crlush Offline
crlush  Offline
Fan needs to be in the engine compartment pulling air from grille.
Re: Overheating issues [Re: ROADRCR] #2113501
07/19/16 07:45 PM
07/19/16 07:45 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Pusher fans work, they are just not as efficient as a puller fan mounted under the hood. That, and they hang out there where everyone can see them and complain about them. Gene
Re: Overheating issues [Re: ROADRCR] #2113527
07/19/16 08:13 PM
07/19/16 08:13 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
A pusher fan in a shroud which is covering much of the radiator will NOT be as effective as a pusher without the shroud. If you're going to stick with a pusher then remove the shroud... otherwise put the fan on the engine side of the radiator with the shroud like it should have been done in the beginning.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Overheating issues [Re: Centerline] #2113691
07/19/16 11:28 PM
07/19/16 11:28 PM
IN
ahy Offline
ahy  Offline
IN
Once you get the fan sorted out If you still have a problem it may be time to work on the water pump. The electric setups are great for drag racing and can cool the engine between rounds with battery charger to help. For street use, I believe a mechanical pump, preferably high volume, works a lot better with more flow at speed.
