A body circuit board
#2111161
07/16/16 02:44 PM
07/16/16 02:44 PM
Posts: 2,502 Shelby, Ohio
2abodymcodes
Shelby, Ohio
Are there any suppliers that sell new dash circuit boards for a 69 barracuda?
Re: A body circuit board
[Re: 2abodymcodes]
#2111705
07/17/16 12:40 PM
07/17/16 12:40 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I've repaired a set and bought an aftermarket set, which I have installed just the other day during a complete dash upgrade and A/C install. Both with good results. The repaired set has lasted for 10+ years, and is still good.
If you fix the set you have pictured, make sure to re-solder the remaining pins to help avoid problems in the future. The repair is not difficult, but the pins must be positioned carefully.
The replacement set I got from Premiumdashdecals.com are very nice quality with a small extra amount of solder at the base of the pins, which makes them a little more robust than the way the factory did it.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 2abodymcodes]
#2111729
07/17/16 01:10 PM
07/17/16 01:10 PM
Posts: 199 NC
1970A66
NC
That board can definitely be repaired if you can find a replacement pin. You need someone experienced with soldering ideally. The trick to making a good repair is cleaning/preparation. Those pins and the copper runs have oxidized and must be cleaned really good (i.e. shiny metal) in order for solder to flow well. I use one of these: https://www.amazon.com/Scratch-Brush-Fiberglass-Colors-vary/dp/B0019V18D2 This brush has fine fiberglass bristles similar to a small paint brush and thus can get into all nooks/crannies. It leaves the surface clean and shiny allowing solder to flow really good making a strong mechanical/electrical connection. A brass brush is is too big and course and won't work as effectively.
[Re: 2abodymcodes]
#2111885
07/17/16 04:47 PM
07/17/16 04:47 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Replacement PCBs are available from multiple suppliers including Charger Specialties... But... Repairing the pin is straight forward and not difficult, also I would recommend that when the PCB is out, U should resolder carefully the base of each pin.. Over time they can weaken and and break loose when removing the connector socket. Just use a low wattage pencil soldering iron (<50W) and the solder will flow easily once the joint is heated.. Just my $0.02...
