A body circuit board #2111161
07/16/16 02:44 PM
07/16/16 02:44 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
Are there any suppliers that sell new dash circuit boards for a 69 barracuda?
Re: A body circuit board [Re: 2abodymcodes] #2111166
07/16/16 02:55 PM
07/16/16 02:55 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Classic Industries does as well as other suppliers. I believe they are the same as the Duster/ Demon rally dash ones. If you shop around you can probably find them cheaper, but heres a link to Classic Industries:
http://www.classicindustries.com/shop/mopar/parts/dash-components/printed-circuits/
Re: A body circuit board [Re: NV69B7RR] #2111177
07/16/16 03:11 PM
07/16/16 03:11 PM
Shelby, Ohio
2
Shelby, Ohio
thanks. I just looked and sew where year one sells them also. should of looked before I posted.
Re: A body circuit board [Re: 2abodymcodes] #2111435
07/16/16 11:15 PM
07/16/16 11:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Looks to be nothing wrong with that one except the mission pin. It can be fixed. The pins are the fault with those. The rest is durable.
Dart clusters have the same pins. You can solder one back on. I've seen somewhere online were someone fixed them and make them stronger. Maybe adding and pin through the hollow hole?? I can't remember.
I'd rather have a good fixed original than taking chances with a repro.
Re: A body circuit board [Re: 2abodymcodes] #2111463
07/17/16 12:09 AM
07/17/16 12:09 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Here's one tip for repair:
Re: A body circuit board [Re: 2abodymcodes] #2111486
07/17/16 12:51 AM
07/17/16 12:51 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Re: A body circuit board [Re: 2abodymcodes] #2111705
07/17/16 12:40 PM
07/17/16 12:40 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I've repaired a set and bought an aftermarket set, which I have installed just the other day during a complete dash upgrade and A/C install. Both with good results. The repaired set has lasted for 10+ years, and is still good.
If you fix the set you have pictured, make sure to re-solder the remaining pins to help avoid problems in the future. The repair is not difficult, but the pins must be positioned carefully.
The replacement set I got from Premiumdashdecals.com are very nice quality with a small extra amount of solder at the base of the pins, which makes them a little more robust than the way the factory did it.
Re: A body circuit board [Re: 2abodymcodes] #2111729
07/17/16 01:10 PM
07/17/16 01:10 PM
NC
1970A66 Offline
1970A66  Offline
NC
That board can definitely be repaired if you can find a replacement pin.
You need someone experienced with soldering ideally.
The trick to making a good repair is cleaning/preparation.
Those pins and the copper runs have oxidized and must be cleaned really good (i.e. shiny metal) in order for solder to flow well.
I use one of these:
https://www.amazon.com/Scratch-Brush-Fiberglass-Colors-vary/dp/B0019V18D2
This brush has fine fiberglass bristles similar to a small paint brush and thus can get into all nooks/crannies. It leaves the surface clean and shiny allowing solder to flow really good making a strong mechanical/electrical connection.
A brass brush is is too big and course and won't work as effectively.
Re: A body circuit board [Re: 2abodymcodes] #2111885
07/17/16 04:47 PM
07/17/16 04:47 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Replacement PCBs are available from multiple suppliers including Charger Specialties...
But...
Repairing the pin is straight forward and not difficult, also I would recommend that when the PCB is out, U should resolder carefully the base of each pin.. Over time they can weaken and and break loose when removing the connector socket. Just use a low wattage pencil soldering iron (<50W) and the solder will flow easily once the joint is heated..
Just my $0.02... wink
