Re: Which intake best for max wedge ports
[Re: 68formulas]
#2104770
07/06/16 10:08 AM
07/06/16 10:08 AM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
Depends on what your doing. I have MW performer heads with a 337 and love it. I also have MW Victors I'm going to use the Super Victor intake on.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: 68formulas]
#2104915
07/06/16 02:17 PM
07/06/16 02:17 PM
fast68plymouth
So. Burlington, Vt.
Unless the particular build is really quite mild, you could take the welded m1 off that list.
[Re: Moparteacher]
#2105045
07/06/16 05:08 PM
07/06/16 05:08 PM
Posts: 31,078 Oregon
AndyF
Is there enough meat on the 337 to shave and install on a low deck? Anyone done this? No way. It would require extensive fabrication to turn it into a low deck intake.
[Re: 68formulas]
#2105099
07/06/16 06:39 PM
07/06/16 06:39 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
I used a Indy 400-3 on my 400 block stroker motor with Eddy Victor M.W. heads with no problems ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) IHTHs ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: 68formulas]
#2105256
07/06/16 10:03 PM
07/06/16 10:03 PM
fast68plymouth
So. Burlington, Vt.
I'm pretty sure the op included the 337 in his post because of the stage 6 heads, which use an RB intake when they're run on a low deck block.
[Re: 68formulas]
#2105306
07/06/16 11:08 PM
07/06/16 11:08 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
It depends on how much power you want to make. I've tried both the '337 and Indy 4500 on my Stg 6/MW/B-engine and the Indy makes more power. That's using a Holley 1150. The '337 is intended to be a shorter intake though. My 4500 adapter makes it the same height as the Indy. Run the '337 with a 4150 and it would probably fit under most hoods. The indy with a slightly angle-milled carb flange fits under my '68 Barracuda hood with about 2-1/2" clearance. The '337 is the same with a customized 4500 adapter. Whats best Mopar 337 Super Victor Indy or Welded up M1 for a low deck block stage 6 max wedge raised intake ports heads.
[Re: rebel]
#2105533
07/07/16 10:58 AM
07/07/16 10:58 AM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
I really Love this ported 337 on my 517, revs like a comp eliminator motor and ( unlike and indy or the Victor) fits under a stock second Gen Charger hood.
I think Andy tested all 3 on his 800 horse 505, i think he said the indy made the most power but it was pretty close. I would really have liked to see the torque curves for all 3 on that motor, I would guess the 337 might have a slightly higher average number, the indy for my builds was much more of a ' light switch' and not great below around 3800, which is to be expected, because it's a full race manifold.
I would reckon the porting of my 337 has more than offset the OOTB top end advantage of the Indy, so (possibly)!the best of both worlds.
On a mid 3 series geared heavy automatic car, I know first-hand that a well ported Indy 440-2d is a very good manifold as well for up to ~700HP
[Re: rebel]
#2105619
07/07/16 12:46 PM
07/07/16 12:46 PM
Thumperdart
State of confusion
The Super Victor was my choice on MW Stage 6 on a low deck. Do you have room for a 1/2" 4-hole spacer Rebel? I recommend them on everything where it will fit, help isolate vibrations and heat and keep the guts out of the engine........
[Re: Thumperdart]
#2105802
07/07/16 06:22 PM
07/07/16 06:22 PM
Posts: 4,647 aotearoa
rebel
aotearoa
The Super Victor was my choice on MW Stage 6 on a low deck. Do you have room for a 1/2" 4-hole spacer Rebel? I recommend them on everything where it will fit, help isolate vibrations and heat and keep the guts out of the engine........ i've since changed carbs & fitted a 950 Quickfuel dual pattern carb & fitted a phenolic isolator to keep the carb cooler. the dominator was a pig to drive at slow speeds.
