Originally Posted By Thumperdart
Originally Posted By rebel
The Super Victor was my choice on MW Stage 6 on a low deck.
Do you have room for a 1/2" 4-hole spacer Rebel? I recommend them on everything where it will fit, help isolate vibrations and heat and keep the guts out of the engine........
i've since changed carbs & fitted a 950 Quickfuel dual pattern carb & fitted a phenolic isolator to keep the carb cooler. the dominator was a pig to drive at slow speeds.
