Which intake best for max wedge ports #2104525
07/05/16 10:23 PM
07/05/16 10:23 PM
Louisiana
68formulas Offline OP
Louisiana
Whats best Mopar 337 Super Victor Indy or Welded up M1 for a low deck block stage 6 max wedge raised intake ports heads.
Re: Which intake best for max wedge ports [Re: 68formulas] #2104584
07/06/16 12:23 AM
07/06/16 12:23 AM
AndyF Offline
AndyF  Offline
Not sure there is a clear winner. I tested all of them and finally decided that the Super Victor was the best for me.
Re: Which intake best for max wedge ports [Re: 68formulas] #2104770
07/06/16 10:08 AM
07/06/16 10:08 AM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
Depends on what your doing. I have MW performer heads with a 337 and love it. I also have MW Victors I'm going to use the Super Victor intake on.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: Which intake best for max wedge ports [Re: 68formulas] #2104915
07/06/16 02:17 PM
07/06/16 02:17 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Unless the particular build is really quite mild, you could take the welded m1 off that list.
Re: Which intake best for max wedge ports [Re: 68formulas] #2105021
07/06/16 04:33 PM
07/06/16 04:33 PM
Boise
Moparteacher Offline
Boise
Is there enough meat on the 337 to shave and install on a low deck? Anyone done this?
Re: Which intake best for max wedge ports [Re: Moparteacher] #2105045
07/06/16 05:08 PM
07/06/16 05:08 PM
AndyF Offline
AndyF  Offline
No way. It would require extensive fabrication to turn it into a low deck intake.
Re: Which intake best for max wedge ports [Re: 68formulas] #2105099
07/06/16 06:39 PM
07/06/16 06:39 PM
I used a Indy 400-3 on my 400 block stroker motor with Eddy Victor M.W. heads with no problems shruggy IHTHs thumbs
Re: Which intake best for max wedge ports [Re: 68formulas] #2105164
07/06/16 08:04 PM
07/06/16 08:04 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
my 400/512 with porters worked over mw port indy ez's has an indy intake, 4150 style. it seems to work fine.
Re: Which intake best for max wedge ports [Re: 68formulas] #2105256
07/06/16 10:03 PM
07/06/16 10:03 PM
So. Burlington, Vt.
So. Burlington, Vt.
I'm pretty sure the op included the 337 in his post because of the stage 6 heads, which use an RB intake when they're run on a low deck block.
Re: Which intake best for max wedge ports [Re: 68formulas] #2105306
07/06/16 11:08 PM
07/06/16 11:08 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
It depends on how much power you want to make. I've tried both the '337 and Indy 4500 on my Stg 6/MW/B-engine and the Indy makes more power. That's using a Holley 1150. The '337 is intended to be a shorter intake though. My 4500 adapter makes it the same height as the Indy. Run the '337 with a 4150 and it would probably fit under most hoods. The indy with a slightly angle-milled carb flange fits under my '68 Barracuda hood with about 2-1/2" clearance. The '337 is the same with a customized 4500 adapter.
Re: Which intake best for max wedge ports [Re: 68formulas] #2105448
07/07/16 03:25 AM
07/07/16 03:25 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
The Super Victor was my choice on MW Stage 6 on a low deck.
Re: Which intake best for max wedge ports [Re: rebel] #2105533
07/07/16 10:58 AM
07/07/16 10:58 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I really Love this ported 337 on my 517, revs like a comp eliminator motor and ( unlike and indy or the Victor) fits under a stock second Gen Charger hood.
I think Andy tested all 3 on his 800 horse 505, i think he said the indy made the most power but it was pretty close. I would really have liked to see the torque curves for all 3 on that motor, I would guess the 337 might have a slightly higher average number, the indy for my builds was much more of a ' light switch' and not great below around 3800, which is to be expected, because it's a full race manifold.
I would reckon the porting of my 337 has more than offset the OOTB top end advantage of the Indy, so (possibly)!the best of both worlds.
On a mid 3 series geared heavy automatic car, I know first-hand that a well ported Indy 440-2d is a very good manifold as well for up to ~700HP
WIZE
In Car:
Re: Which intake best for max wedge ports [Re: rebel] #2105619
07/07/16 12:46 PM
07/07/16 12:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Do you have room for a 1/2" 4-hole spacer Rebel? I recommend them on everything where it will fit, help isolate vibrations and heat and keep the guts out of the engine........
Re: Which intake best for max wedge ports [Re: Thumperdart] #2105802
07/07/16 06:22 PM
07/07/16 06:22 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i've since changed carbs & fitted a 950 Quickfuel dual pattern carb & fitted a phenolic isolator to keep the carb cooler. the dominator was a pig to drive at slow speeds.
