exhaust dump question #2104776
07/06/16 10:19 AM
07/06/16 10:19 AM
michigan
turbo toad Offline OP
michigan
This my be a dumb question but one Ive been thinking about for the last couple weeks. Im getting close to having my new mill all mocked up and im getting ready to start fabbing up my downpipes off the turbos,plans are to dump the DP Behind the front tires out the side of fenders. And was curious if theres any gains to be had by running 90° bends pointing to the rear of the car which seams to be the rage right now.
The reason i ask this question I was watching NHRA Promods the other day and one of the announcers made reference about the exhaust propelling the car down the track,is there a point when a high HP car will see some benefits from exhaust thrust?
Thanks in advance
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: exhaust dump question [Re: turbo toad] #2104779
07/06/16 10:25 AM
07/06/16 10:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I hear that the top fuel pipes will put out 800
lbs of force at each pipe.. if you run BIG pressure
it could help slightly
wave
Re: exhaust dump question [Re: MR_P_BODY] #2104788
07/06/16 10:43 AM
07/06/16 10:43 AM
when I took up jogging and became a 98% vegan I lost more weight than the weight difference from iron to an alum manifold/MC/pump housing/& even 440 source heads combined! I felt better & the car was faster! just a thought till my coffee is ready
Re: exhaust dump question [Re: RapidRobert] #2104791
07/06/16 10:55 AM
07/06/16 10:55 AM
michigan
michigan
Lol I feel that way after a morning poop...just playing with yah Rapid coffee
Re: exhaust dump question [Re: turbo toad] #2104826
07/06/16 11:41 AM
07/06/16 11:41 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
It couldnt hurt, but with that car, two holes in the tops of the fenders with some real annoying rain caps would be my choice. up
Re: exhaust dump question [Re: TRENDZ] #2104843
07/06/16 12:02 PM
07/06/16 12:02 PM
michigan
michigan
Trendz ill give that some thought thanks
Re: exhaust dump question [Re: RapidRobert] #2104867
07/06/16 12:54 PM
07/06/16 12:54 PM
Az
Crizila Offline
Crizila  Offline
Az
laugh - I'm already on my second cup!
Fastest 300
Re: exhaust dump question [Re: turbo toad] #2104898
07/06/16 02:03 PM
07/06/16 02:03 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I thought some of the pro mod/outlaw guys were using the bullhorns facing upward (not just rearward) to provide a slight bit of downforce help to keep the front end down at speed. 3000+ hp moves a lot of air.
Re: exhaust dump question [Re: turbo toad] #2104903
07/06/16 02:09 PM
07/06/16 02:09 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I think the guy at the tree prefers anything that's not aimed at him!
Re: exhaust dump question [Re: turbo toad] #2104961
07/06/16 02:59 PM
07/06/16 02:59 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
This is a turbo car. Any effect will be dampened greatly.
Keep the down pipes short and sweet. You can have the bull horn attach with V-bands so you can still remove the doghouse easy.
Re: exhaust dump question [Re: FastmOp] #2105274
07/06/16 10:28 PM
07/06/16 10:28 PM
michigan
michigan
FastmOp thats how i planned on doing it as easy as possible I'm a one man operation and have to beable to do anything on the car by myself,but i see more and more fast guys running there exhaust that way and i was just curious if anyone has seen any real world data on the benefits of running there DP like this.
