exhaust dump question
#2104776
07/06/16 10:19 AM
07/06/16 10:19 AM
Posts: 368 michigan
turbo toad
michigan
This my be a dumb question but one Ive been thinking about for the last couple weeks. Im getting close to having my new mill all mocked up and im getting ready to start fabbing up my downpipes off the turbos,plans are to dump the DP Behind the front tires out the side of fenders. And was curious if theres any gains to be had by running 90° bends pointing to the rear of the car which seams to be the rage right now. The reason i ask this question I was watching NHRA Promods the other day and one of the announcers made reference about the exhaust propelling the car down the track,is there a point when a high HP car will see some benefits from exhaust thrust? Thanks in advance
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: exhaust dump question
[Re: turbo toad]
#2104779
07/06/16 10:25 AM
07/06/16 10:25 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I hear that the top fuel pipes will put out 800 lbs of force at each pipe.. if you run BIG pressure it could help slightly
[Re: MR_P_BODY]
#2104788
07/06/16 10:43 AM
07/06/16 10:43 AM
RapidRobert
when I took up jogging and became a 98% vegan I lost more weight than the weight difference from iron to an alum manifold/MC/pump housing/& even 440 source heads combined! I felt better & the car was faster! just a thought till my coffee is ready
[Re: RapidRobert]
#2104791
07/06/16 10:55 AM
07/06/16 10:55 AM
Posts: 368 michigan
turbo toad
michigan
when I took up jogging and became a 98% vegan I lost more weight than the weight difference from iron to an alum manifold/MC/pump housing/& even 440 source heads combined! I felt better & the car was faster! just a thought till my coffee is ready Lol I feel that way after a morning poop...just playing with yah Rapid
[Re: TRENDZ]
#2104843
07/06/16 12:02 PM
07/06/16 12:02 PM
Posts: 368 michigan
turbo toad
michigan
It couldnt hurt, but with that car, two holes in the tops of the fenders with some real annoying rain caps would be my choice. Trendz ill give that some thought thanks
[Re: RapidRobert]
#2104867
07/06/16 12:54 PM
07/06/16 12:54 PM
Posts: 7,506 Az
Crizila
Az
when I took up jogging and became a 98% vegan I lost more weight than the weight difference from iron to an alum manifold/MC/pump housing/& even 440 source heads combined! I felt better & the car was faster! just a thought till my coffee is ready - I'm already on my second cup!
Fastest 300
[Re: turbo toad]
#2104898
07/06/16 02:03 PM
07/06/16 02:03 PM
Posts: 8,172 Plymouth, MI
Blusmbl
Plymouth, MI
I thought some of the pro mod/outlaw guys were using the bullhorns facing upward (not just rearward) to provide a slight bit of downforce help to keep the front end down at speed. 3000+ hp moves a lot of air.
[Re: turbo toad]
#2104903
07/06/16 02:09 PM
07/06/16 02:09 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I think the guy at the tree prefers anything that's not aimed at him!
[Re: FastmOp]
#2105274
07/06/16 10:28 PM
07/06/16 10:28 PM
Posts: 368 michigan
turbo toad
michigan
This is a turbo car. Any effect will be dampened greatly.
Keep the down pipes short and sweet. You can have the bull horn attach with V-bands so you can still remove the doghouse easy. FastmOp thats how i planned on doing it as easy as possible I'm a one man operation and have to beable to do anything on the car by myself,but i see more and more fast guys running there exhaust that way and i was just curious if anyone has seen any real world data on the benefits of running there DP like this.
