is a 750 to much carb for a hi po 383 eng #2103909
07/04/16 09:40 PM
07/04/16 09:40 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
mild roller cam and headers,906 heads.for street only.these cars came from factory with a 600 carb and was running pretty good then, thanks
Re: is a 750 to much carb for a hi po 383 eng [Re: moparpro] #2103913
07/04/16 09:45 PM
07/04/16 09:45 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
But no factory 383's came with roller cams or headers.
750cfm no problem at all.
400's came with 850 cfm.
340/360's came with 800 cfm
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: is a 750 to much carb for a hi po 383 eng [Re: moparpro] #2103924
07/04/16 10:02 PM
07/04/16 10:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
360's and 400's also came with 2bbl carbs, so that's not a real good indicator.
A roller cam, in and of itself, is no indication of anything. my 87 318 came with a stock roller cam and a 2bbl.
spec's on the engine build would be better.
My experience is that both cams and carbs are better off going a bit more conservative than the opposite for anything "street only".
Don't be the exception.
Re: is a 750 to much carb for a hi po 383 eng [Re: moparpro] #2103925
07/04/16 10:04 PM
07/04/16 10:04 PM
Ohio
dobie Offline
dobie  Offline
Ohio
My RR loves its little 650DP. I have a 750 DP as well but the car doesnt run near as well. Major bogs, hesitation, sputtering, etc. Both carbs were rebuilt by the same guy at the same time. Both were put back to Holley specs with the proper jets. I took the 750 back a second time to have him go thru it again with the guy even driving it with the 750 installed. For some reason my car just likes the 650. Either that, or there's something wrong with the 750 that hasnt been caught yet. My car has headers, mild cam and head work (906's), 4 speed. Who knows.
Re: is a 750 to much carb for a hi po 383 eng [Re: Supercuda] #2103927
07/04/16 10:07 PM
07/04/16 10:07 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Oh Lord here we go..
You guys would be doomed running a six pack laugh2
Re: is a 750 to much carb for a hi po 383 eng [Re: moparpro] #2103935
07/04/16 10:13 PM
07/04/16 10:13 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
My built 383 loves 670 cfm. Tried a 750 and it ran worse. Also have a 650 on a 400 hp 360 and it likes it. Again, tried a 750 and it ran worse. Sometimes I think it is too much air that kills performance as much as the fuel.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: is a 750 to much carb for a hi po 383 eng [Re: dfsmopars] #2103957
07/04/16 10:47 PM
07/04/16 10:47 PM
Alberta
440_Offroader Offline
Alberta
I know many hate them, but I have a RARE edelbrock performer 750, that actually works really well on my 383. Lightly worked 906's, rpm intake, mild cam, and headers. That's it.
Re: is a 750 to much carb for a hi po 383 eng [Re: moparpro] #2103966
07/04/16 10:59 PM
07/04/16 10:59 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Same size carb came on the 1st Gen z28 302. Nobody complained about it being too big.
Yours is probably setup wrong for your combo. Find someone that is good with holley carbs to tune it on the car instead of your rebuilder guessing on his workbench.
Bigger carb may need timing advance curve changes to work properly.
Re: is a 750 to much carb for a hi po 383 eng [Re: moparpro] #2104014
07/05/16 12:14 AM
07/05/16 12:14 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
My son ran our 1407 Edelbrock 750 on the 302 that was in his wife's Mustang when they got it. Why? It's the only good four barrel we had to get it running on without spending any money. It ran fine, but probably didn't get the fuel mileage that it would have with a smaller carb.
Re: is a 750 to much carb for a hi po 383 eng [Re: moparpro] #2104026
07/05/16 12:56 AM
07/05/16 12:56 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i have a 750DP with annular boosters on the 360 in my car. modest cam, maybe a 272, good compression, hi-rise dual plane intake, it's completely factory tune on the carb right now except i drilled the IFR's and went down a step there, cleaned up the transition and it runs fine on the street.
2.94 gears and maybe a factory high stall converter, flashes to maybe 2500.
Re: is a 750 to much carb for a hi po 383 eng [Re: moparpro] #2104083
07/05/16 06:08 AM
07/05/16 06:08 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
The 5.9 in my Duster will pull a vacuum at WOT with the 625 CFM AFB, since finding that out swapped to 750 AFB. Runs 13.0 at 104 mph.
A 750 will be fine on a 383.
"I think its got a hemi"
Re: is a 750 to much carb for a hi po 383 eng [Re: moparpro] #2104091
07/05/16 08:36 AM
07/05/16 08:36 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
I have a Holley street hp 750 on the 400 on my dart and it runs great.
Re: is a 750 to much carb for a hi po 383 eng [Re: moparpro] #2104129
07/05/16 10:39 AM
07/05/16 10:39 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the 750-800 holleys are near perfect for a 383. if tuning skills are lacking it wouldn't make much difference what the "ideal carb" would be; then one would have to rely on random "luck".
i did run a dp6b back in the day. a lot of possibilities here but expensive to do right.
Re: is a 750 to much carb for a hi po 383 eng [Re: GomangoCuda] #2104481
07/05/16 09:36 PM
07/05/16 09:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Nope, but lots of comments about soggy bottom ends and not being a very good "street only" car.
I ran a 750 on my 225 when I put a 4bbl intake on it because that was the carb I had.
Did it work? yes.
Was it optimal, not by a long shot.
You could probably take the carb off your lawn mower and get it to "work" too.
Re: is a 750 to much carb for a hi po 383 eng [Re: lewtot184] #2104485
07/05/16 09:40 PM
07/05/16 09:40 PM
dogdays Offline
dogdays  Offline
Back in the day, EVERYONE knew that a 383 would run much better with the carb from a 440 on top of it. I imagine the carb to use was the one from the higher performance 440. Shoot, that carb was even the right one for 340s!
AFBs and AVSs have a secondary that opens on demand so the carb is only as big as the engine needs. I ran a 600 Holley for several years on my low po 318 with decent mileage and driveability. It ran better with a later 570 Street Avenger but I attribute that to a better fuel curve.
The tune on the carb is more important than the cfm. That's one more reason that fuel injection is so good, at least the ones that use an O2 sensor.
R.
Re: is a 750 to much carb for a hi po 383 eng [Re: moparpro] #2104493
07/05/16 09:48 PM
07/05/16 09:48 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
When I bought my RR it had a vac sec 750 that ran like crap. I've spent some time with Holleys. So I jetted it, changed PV and squirters and it ran like a scalded dog for a bone stock, 50,000 mile original 383.
Because my car is so original, I went back to the original 383 AVS (properly jetted) and it probably killed at least 20 HP.
No a 750 is not too much. As said, other makes used that size on much smaller motors from the factory, for a reason! Back in the day, installing a 440 carb on a 383 was worth plenty.
Re: is a 750 to much carb for a hi po 383 eng [Re: Supercuda] #2104526
07/05/16 10:24 PM
07/05/16 10:24 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
iagree
I'm running a mild 383 in a '68 Road Runner. Speed Pro 2315 pistons, stealth heads, 9.7:1, XE 268 cam, Perf. RPM intake, factory HP manifolds with an 1806 (650) Edelbrock. Runs GREAT with a 727/3.23's. thumbs
Re: is a 750 to much carb for a hi po 383 eng [Re: Supercuda] #2104639
07/06/16 01:32 AM
07/06/16 01:32 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Did it work? yes.
Of course 1st gen Z/28s had soggy bottom ends. It was only a 302 and it had a pretty hot cam. I doubt the 780 carb hurt it too much.
