Re: is a 750 to much carb for a hi po 383 eng
[Re: moparpro]
#2103913
07/04/16 09:45 PM
07/04/16 09:45 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
But no factory 383's came with roller cams or headers.
750cfm no problem at all.
400's came with 850 cfm.
340/360's came with 800 cfm
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: moparpro]
#2103924
07/04/16 10:02 PM
07/04/16 10:02 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
360's and 400's also came with 2bbl carbs, so that's not a real good indicator.
A roller cam, in and of itself, is no indication of anything. my 87 318 came with a stock roller cam and a 2bbl.
spec's on the engine build would be better.
My experience is that both cams and carbs are better off going a bit more conservative than the opposite for anything "street only".
[Re: Supercuda]
#2103927
07/04/16 10:07 PM
07/04/16 10:07 PM
DARTH V8Я
Its a TRAP!
My experience is that both cams and carbs are better off going a bit more conservative than the opposite for anything "street only". Oh Lord here we go.. You guys would be doomed running a six pack
[Re: moparpro]
#2103935
07/04/16 10:13 PM
07/04/16 10:13 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
My built 383 loves 670 cfm. Tried a 750 and it ran worse. Also have a 650 on a 400 hp 360 and it likes it. Again, tried a 750 and it ran worse. Sometimes I think it is too much air that kills performance as much as the fuel.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: moparpro]
#2103966
07/04/16 10:59 PM
07/04/16 10:59 PM
Posts: 4,722 Moved to N.E. Tennessee
GomangoCuda
Same size carb came on the 1st Gen z28 302. Nobody complained about it being too big.
Yours is probably setup wrong for your combo. Find someone that is good with holley carbs to tune it on the car instead of your rebuilder guessing on his workbench.
Bigger carb may need timing advance curve changes to work properly.
[Re: moparpro]
#2104083
07/05/16 06:08 AM
07/05/16 06:08 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
The 5.9 in my Duster will pull a vacuum at WOT with the 625 CFM AFB, since finding that out swapped to 750 AFB. Runs 13.0 at 104 mph.
A 750 will be fine on a 383.
"I think its got a hemi"
[Re: GomangoCuda]
#2104481
07/05/16 09:36 PM
07/05/16 09:36 PM
Supercuda
About to go away
About to go away
up yours
Same size carb came on the 1st Gen z28 302. Nobody complained about it being too big. Nope, but lots of comments about soggy bottom ends and not being a very good "street only" car. I ran a 750 on my 225 when I put a 4bbl intake on it because that was the carb I had. Did it work? yes. Was it optimal, not by a long shot. You could probably take the carb off your lawn mower and get it to "work" too.
[Re: lewtot184]
#2104485
07/05/16 09:40 PM
07/05/16 09:40 PM
dogdays
Back in the day, EVERYONE knew that a 383 would run much better with the carb from a 440 on top of it. I imagine the carb to use was the one from the higher performance 440. Shoot, that carb was even the right one for 340s!
AFBs and AVSs have a secondary that opens on demand so the carb is only as big as the engine needs. I ran a 600 Holley for several years on my low po 318 with decent mileage and driveability. It ran better with a later 570 Street Avenger but I attribute that to a better fuel curve.
The tune on the carb is more important than the cfm. That's one more reason that fuel injection is so good, at least the ones that use an O2 sensor.
R.
[Re: Supercuda]
#2104639
07/06/16 01:32 AM
07/06/16 01:32 AM
Posts: 1,458 oklahoma
forphorty
oklahoma
Same size carb came on the 1st Gen z28 302. Nobody complained about it being too big. Nope, but lots of comments about soggy bottom ends and not being a very good "street only" car. I ran a 750 on my 225 when I put a 4bbl intake on it because that was the carb I had. Did it work? yes. Was it optimal, not by a long shot. You could probably take the carb off your lawn mower and get it to "work" too. Of course 1st gen Z/28s had soggy bottom ends. It was only a 302 and it had a pretty hot cam. I doubt the 780 carb hurt it too much.
