MSD Controller Harness #2099839
06/28/16 10:27 AM
06/28/16 10:27 AM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
I have a 05 5.7 with early 2 pin coils. Looks like the harness for the early coils have been discontinued by MSD?
Also I have a set of Eagle heads that I will eventually like to use.
What do I need to switch to the later model coils and that would work with both heads?
Re: MSD Controller Harness [Re: RTSE4ME] #2099894
06/28/16 11:49 AM
06/28/16 11:49 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Buy the later coils and the proper harness for the MSD and you're good. You'll also need the later valve covers as well.
Re: MSD Controller Harness [Re: STEFF] #2099964
06/28/16 02:00 PM
06/28/16 02:00 PM
Renton Washington
Triple Threat Offline
Renton Washington
Agreed
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: MSD Controller Harness [Re: RTSE4ME] #2100273
06/28/16 11:26 PM
06/28/16 11:26 PM
NJ, USA
Hemijoejr Offline
Hemijoejr  Offline
NJ, USA
I just bought one for the early coils and installed it no more than 2 weeks ago. They are not listed on Summit Racing any more. Just the later setup. I ordered mine off of EBay and it was drop shipped from MSD.
Stock Displacement, pump gas, 5.7L Gen 3 Hemi, early 5.7L heads, 3670lbs with driver, Best time and MPH 11.11@120.9MPH
Re: MSD Controller Harness [Re: Hemijoejr] #2100291
06/28/16 11:54 PM
06/28/16 11:54 PM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
Thanks Steff
Can I use 06-08 valve covers on Eagle heads? Or do I need the 09 and later valve covers?
If I keep the early coils can they be used when I swap to Eagle heads? The old harness is still available on ebay but it is no longer on MSD site.
Trying to figure out which way to go without having buy things twice.
Re: MSD Controller Harness [Re: RTSE4ME] #2100434
06/29/16 08:48 AM
06/29/16 08:48 AM
NJ, USA
Hemijoejr Offline
Hemijoejr  Offline
NJ, USA
No, you need Eagle specific valve covers due to the updated valve train geometry and they require the later style coils.
Re: MSD Controller Harness [Re: RTSE4ME] #2101161
06/30/16 03:19 PM
06/30/16 03:19 PM
Renton Washington
Renton Washington
Thanks Steff
I am using 06-08 valve covers and coils on my Apache headed 392. Some trimming was required to the internal braces.
-Dustin
