Pertronix is an easy install. Take the points and condensor out,put them in your glove box.
Install the magnetic pickup plate,then the reluctor over the shaft of the dizzy. Gap the pickup with the plastic piece provided,install the rotor provided and the cap. Run the wires,Red to + side of the coil,Black to the - Side of the coil. DONE!! Everything is under the stock cap and looks like an OEM setup.
It is recommended you also purchase a Flamethrower coil for a hotter spark,I didnt though and the car runs alright.
