Pertronix ignition #210086
02/01/09 12:43 AM
02/01/09 12:43 AM
JJ6PACK Offline OP
JJ6PACK  Offline OP
I've had some problems with the points,should I try electronic ignition?Does it make a horsepower difference?The other issue is authenticity,is it worth it?
Re: Pertronix ignition [Re: JJ6PACK] #210087
02/01/09 12:48 AM
02/01/09 12:48 AM
Cochise County Arizona
SPWC Offline
SPWC  Offline
Pertronix is an easy install. Take the points and condensor out,put them in your glove box.
Install the magnetic pickup plate,then the reluctor over the shaft of the dizzy. Gap the pickup with the plastic piece provided,install the rotor provided and the cap. Run the wires,Red to + side of the coil,Black to the - Side of the coil. DONE!! Everything is under the stock cap and looks like an OEM setup.
It is recommended you also purchase a Flamethrower coil for a hotter spark,I didnt though and the car runs alright.
Re: Pertronix ignition [Re: JJ6PACK] #210088
02/01/09 12:52 AM
02/01/09 12:52 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
this is well worth the price,I installed it on my 67 bele 2 and it was like night and day, starting was a snap and had a smoother idle also.
Re: Pertronix ignition [Re: moparsquid] #210089
02/01/09 01:06 AM
02/01/09 01:06 AM
JJ6PACK Offline OP
JJ6PACK  Offline OP
Thanks for the info,I'm on the fence.I'm trying to keep original but starting and the top end has been bad.
Re: Pertronix ignition [Re: JJ6PACK] #210090
02/01/09 03:06 PM
02/01/09 03:06 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
Pertronix is comming out with an ignitor III in march, supposed to be some kinda multi spark i beleive..
