Stroker fuel pump question #2100207
06/28/16 09:59 PM
06/28/16 09:59 PM
Spencer NY
killermopar Offline OP
Spencer NY
My brother is running a 414 small block. It has approx 12 to 1 compression ratio, ported j heads with 2.08 valves, and a .508- 292* comp cam. He was running 1/8 mile in his truck and it lays over. I know it's the fuel pump ( he's running a factory type block pump), my question is... Is there a block pump made that can keep up? Thank you guys.
Re: Stroker fuel pump question [Re: killermopar] #2100215
06/28/16 10:10 PM
06/28/16 10:10 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Get rid of the in tank screen on the pickup tube and add an inline filter. Holley and Carter have always made good mechanical pumps.
[image][/image]
Re: Stroker fuel pump question [Re: sgcuda] #2100253
06/28/16 10:59 PM
06/28/16 10:59 PM
plumb a can of fuel to the pump inlet & repeat to see if it is a pump issue or problem in the line rearward including the sock as mentioned. I'm assuming the line from pump to carb is adequate dia & has a high enough capacity filter?
Re: Stroker fuel pump question [Re: killermopar] #2100269
06/28/16 11:22 PM
06/28/16 11:22 PM
Spencer NY
Spencer NY
He has a fuel cell with a 3/8 line.
Re: Stroker fuel pump question [Re: killermopar] #2100270
06/28/16 11:22 PM
06/28/16 11:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
All stock lines.. look for any kinks
wave
Re: Stroker fuel pump question [Re: killermopar] #2100289
06/28/16 11:50 PM
06/28/16 11:50 PM
Spencer NY
Spencer NY
Thank you guys. We will be checking it out. I watched it nose down in high gear. So I know it's starvation of some kind.
Re: Stroker fuel pump question [Re: killermopar] #2100322
06/29/16 12:21 AM
06/29/16 12:21 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Get a carter mechanical race pump. I ran a 6.29 @ 109 in the 1/8 with one.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Stroker fuel pump question [Re: D-50] #2100383
06/29/16 01:46 AM
06/29/16 01:46 AM
Az
Crizila Offline
Crizila  Offline
Az
up one of the best mechanical pumps out there.
Fastest 300
Re: Stroker fuel pump question [Re: Crizila] #2100446
06/29/16 09:59 AM
06/29/16 09:59 AM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
