Re: Stroker fuel pump question
[Re: sgcuda]
#2100253
06/28/16 10:59 PM
06/28/16 10:59 PM
RapidRobert
plumb a can of fuel to the pump inlet & repeat to see if it is a pump issue or problem in the line rearward including the sock as mentioned. I'm assuming the line from pump to carb is adequate dia & has a high enough capacity filter?
[Re: killermopar]
#2100322
06/29/16 12:21 AM
06/29/16 12:21 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Get a carter mechanical race pump. I ran a 6.29 @ 109 in the 1/8 with one.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#2100383
06/29/16 01:46 AM
06/29/16 01:46 AM
Posts: 7,506 Az
Crizila
Az
Get a carter mechanical race pump. I ran a 6.29 @ 109 in the 1/8 with one. one of the best mechanical pumps out there.
Fastest 300
[Re: Crizila]
#2100446
06/29/16 09:59 AM
06/29/16 09:59 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
