Canton racing products, SB Oil filter plate, Install ??? #2097986
06/25/16 04:51 PM
06/25/16 04:51 PM
SINY
SanityLost Offline OP
SINY
Seems like every Saturday something comes up...
I received the filter plate, looking over the instructions they are rather vague ( I know instructions HA) Anyway, Does the attaching nut get some type of washer on it? OR is the supplied O ring that is on the plate the only seal against the block?
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: SanityLost] #2097992
06/25/16 05:01 PM
06/25/16 05:01 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Gasket on the adaptor nut & o-ring on the plate.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: DARTH V8Я] #2098016
06/25/16 05:42 PM
06/25/16 05:42 PM
SINY
SINY
Thanks, the O ring I got that, Now The adapter nut, The gasket on the block side in back of the filter plate where it rests against the block?
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: SanityLost] #2098037
06/25/16 06:28 PM
06/25/16 06:28 PM
Spahn Ranch
RMCHRGR Online work
RMCHRGR  Online Work
Spahn Ranch
No gasket under the threaded adapter. I spoke with Canton about this very thing.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: RMCHRGR] #2098060
06/25/16 07:02 PM
06/25/16 07:02 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Somebody please explain what this achieves.
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: jcc] #2098062
06/25/16 07:05 PM
06/25/16 07:05 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Nothing other then moving the oil filter further out, some extra holes, and 60 buck lighter wallet.
Supposed to stop leaks too..
IF you have a clean mating surface & torque to specs the factoey plate is more then adequate. JMO.
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: jcc] #2098066
06/25/16 07:13 PM
06/25/16 07:13 PM
Spahn Ranch
RMCHRGR Online work
RMCHRGR  Online Work
Spahn Ranch
The OE style 'plate' thing relies on proper torque to work correctly. When you tighten down the adapter nut, the edges crush and the area around the threaded adapter pinches inward. If you gorilla it, it can warp and leak like crazy. The right angle adapters are known to leak as well.
So, if yours leaks, do you go to the dealer or wherever and buy a new plate and gasket kit or do you buy the cool guy Canton part and reuse it on your next block?
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: RMCHRGR] #2098072
06/25/16 07:24 PM
06/25/16 07:24 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Zero leakage issues with mine or Matts and NEVER have I used a torque wrench to tighten it. We both use 90 degree adaptors and Superformance Gaskets.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: SanityLost] #2098082
06/25/16 07:38 PM
06/25/16 07:38 PM
Spahn Ranch
RMCHRGR Online work
RMCHRGR  Online Work
Spahn Ranch
Not saying the OE plates don't work, because in most instances, if properly installed with the correct gaskets, they're fine. But that's the same thing with any part.
I have seen where they leak though, especially when re-used, re-tightened, etc. Leaks could also be from irregular surfaces on the block.
The one 'advantage' of the Canton plate is that it has more holes to allow more oil into and out of the filter. Necessary? Probably not but it's a good idea in theory.
Just a 'better mousetrap' I suppose, nothing real special about it. They're only like $42 though so why not?
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: SanityLost] #2098092
06/25/16 07:59 PM
06/25/16 07:59 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Dots are where I drill the extra holes (black dots) laugh
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: DARTH V8Я] #2098095
06/25/16 08:03 PM
06/25/16 08:03 PM
PA.
"Little"John
"Little"John
PA.
Do some research on oil filters and you will be surprised by how little or often you oil filter is actually filtering oil
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: SanityLost] #2098106
06/25/16 08:24 PM
06/25/16 08:24 PM
SINY
SINY
Thanks for the pictures and the info, exactly what I was hoping to see.
As for the benefit of it, In my case I had the 90* adapter in my 70 swinger. before pulling the motor I changed the oil and man what a pain in the ass it was with the filter and the torsion bar, there was no easy way to get the filter wrench on there. So doing some research I came across this type of filter mount...hopefully it makes it easier to change it out for me, as nothing else has gone easy since purchasing this car mad
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: pittsburghracer] #2098112
06/25/16 08:34 PM
06/25/16 08:34 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
That's when non-bypass filters & high volume (not high pressure) pumps are your friend.
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: SanityLost] #2098129
06/25/16 09:09 PM
06/25/16 09:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Actually there are 3 gaskets in the MP set...
a thick cork that goes under the plate on the center
bolt, the big gasket on the outer edge and then a thin
paper style gasket that goes under the head of the center
nut/stud... I just found a old MP filter kit a day ago that
I will use on my next build.. unless I go remote.. remote
is easier for me to get the filter off
EDIT
That kit has the plate.. bolt/stud and the 3 gaskets
wave
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: SanityLost] #2098246
06/26/16 01:09 AM
06/26/16 01:09 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
The factory plate leaked no matter what I tried on my X-block, went with the Canton piece and never had another problem, that made it worth every cent as far as I was concerned.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: jcc] #2098263
06/26/16 01:44 AM
06/26/16 01:44 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Well, now I know. up
Re: Canton racing products, SB Oil filter plate, Install ??? [Re: SanityLost] #2098394
06/26/16 10:24 AM
06/26/16 10:24 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
In my case I just didn't have a stock one. I thought the canton piece was a good value so I bought it. Worth the money in my opinion.
68 Barracuda Formula S 340
