Re: Canton racing products, SB Oil filter plate, Install ???
[Re: SanityLost]
#2097992
06/25/16 05:01 PM
06/25/16 05:01 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Gasket on the adaptor nut & o-ring on the plate.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: RMCHRGR]
#2098060
06/25/16 07:02 PM
06/25/16 07:02 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Somebody please explain what this achieves.
[Re: jcc]
#2098062
06/25/16 07:05 PM
06/25/16 07:05 PM
DARTH V8Я
Its a TRAP!
Somebody please explain what this achieves. Nothing other then moving the oil filter further out, some extra holes, and 60 buck lighter wallet. Supposed to stop leaks too.. IF you have a clean mating surface & torque to specs the factoey plate is more then adequate. JMO.
[Re: jcc]
#2098066
06/25/16 07:13 PM
06/25/16 07:13 PM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
Somebody please explain what this achieves. The OE style 'plate' thing relies on proper torque to work correctly. When you tighten down the adapter nut, the edges crush and the area around the threaded adapter pinches inward. If you gorilla it, it can warp and leak like crazy. The right angle adapters are known to leak as well. So, if yours leaks, do you go to the dealer or wherever and buy a new plate and gasket kit or do you buy the cool guy Canton part and reuse it on your next block?
'71 Duster '17 Ram 1500
[Re: RMCHRGR]
#2098072
06/25/16 07:24 PM
06/25/16 07:24 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Zero leakage issues with mine or Matts and NEVER have I used a torque wrench to tighten it. We both use 90 degree adaptors and Superformance Gaskets.
[Re: SanityLost]
#2098082
06/25/16 07:38 PM
06/25/16 07:38 PM
RMCHRGR
Spahn Ranch
Not saying the OE plates don't work, because in most instances, if properly installed with the correct gaskets, they're fine. But that's the same thing with any part.
I have seen where they leak though, especially when re-used, re-tightened, etc. Leaks could also be from irregular surfaces on the block.
The one 'advantage' of the Canton plate is that it has more holes to allow more oil into and out of the filter. Necessary? Probably not but it's a good idea in theory.
Just a 'better mousetrap' I suppose, nothing real special about it. They're only like $42 though so why not?
[Re: DARTH V8Я]
#2098095
06/25/16 08:03 PM
06/25/16 08:03 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Do some research on oil filters and you will be surprised by how little or often you oil filter is actually filtering oil
[Re: pittsburghracer]
#2098112
06/25/16 08:34 PM
06/25/16 08:34 PM
DARTH V8Я
Its a TRAP!
Do some research on oil filters and you will be surprised by how little or often you oil filter is actually filtering oil That's when non-bypass filters & high volume (not high pressure) pumps are your friend.
[Re: SanityLost]
#2098129
06/25/16 09:09 PM
06/25/16 09:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Actually there are 3 gaskets in the MP set... a thick cork that goes under the plate on the center bolt, the big gasket on the outer edge and then a thin paper style gasket that goes under the head of the center nut/stud... I just found a old MP filter kit a day ago that I will use on my next build.. unless I go remote.. remote is easier for me to get the filter off EDIT That kit has the plate.. bolt/stud and the 3 gaskets
[Re: SanityLost]
#2098246
06/26/16 01:09 AM
06/26/16 01:09 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
The factory plate leaked no matter what I tried on my X-block, went with the Canton piece and never had another problem, that made it worth every cent as far as I was concerned.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: jcc]
#2098263
06/26/16 01:44 AM
06/26/16 01:44 AM
jcc
Bitopia
Somebody please explain what this achieves. Well, now I know.
[Re: SanityLost]
#2098394
06/26/16 10:24 AM
06/26/16 10:24 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
In my case I just didn't have a stock one. I thought the canton piece was a good value so I bought it. Worth the money in my opinion.
68 Barracuda Formula S 340
