Re: Racepak and 8 3/4???? Driveshaft sensor mount??
[Re: DemonDust]
#2095886
06/21/16 09:58 PM
06/21/16 09:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I had to make magnetic pickup... no one made one for a 8 3/4. ..the pick up is mounted to the snubber holes
[Re: DemonDust]
#2096037
06/22/16 02:36 AM
06/22/16 02:36 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The collar mounted on the front of the driveshaft will move a lot forward and backward on a ladderbar car, and I wouldn't even try it on a leafspring only car. If mine doesn't work where it is by the front yoke(ladderbars) I will either have to mount two rings together or weld a boss on the tail shaft and either use the parking lugs or mount a collar in there.
[Re: DemonDust]
#2096175
06/22/16 12:16 PM
06/22/16 12:16 PM
MR_P_BODY
How did you guys mount your magnets on your yoke? I have no where to put the collar. I dont know why your dust shield sticks out so far but if you can push it back you will have plenty of room.. also... if you notice in the couple of pics that the magnets themselves are only a 1/4" in diameter so you dont need to make it much thicker than that EDIT Or do as Monte said.. trash the dust shield and slide the magnet housing to the rear(just clear the case)
[Re: DemonDust]
#2096208
06/22/16 01:25 PM
06/22/16 01:25 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Machine the yoke if needed or it can go on the shaft itself. The Cuda was mounted on the driveshaft for years with no issue but it was a 4 link deal.
[Re: Al_Alguire]
#2096214
06/22/16 01:41 PM
06/22/16 01:41 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Summit has different yokes available that would probably fix your issues and be stronger too.
[Re: DemonDust]
#2096390
06/22/16 08:11 PM
06/22/16 08:11 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Stronger? That's a 1350 yoke from Dr Diff.
What's weak about it? My mistake I thought it was a stock one. My Dana has the same issue so I will be ordering one from Summit so I can mount my ring on it
[Re: DemonDust]
#2180686
10/23/16 02:31 AM
10/23/16 02:31 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
A little late to the game on this but I thought I would add it in case it helps someone. A little garage fab from some scrap aluminum, and a racepak collar, plus a cherry hall effect sensor and bingo, driveshaft RPM sensor. I will use this to log driveshaft speed as well as show MPH on my megasquirt. This is a Moser yoke that I already was using, it has a nice machine 2.125 surface to mount a collar.
68 Barracuda Formula S 340
[Re: DemonDust]
#2180963
10/23/16 07:09 PM
10/23/16 07:09 PM
Bad340fish
Tulsa OK
This will be short lived, I am putting in my spare center section since I broke two teeth off of the one you see pictured. I just bought a D60 housing to start the journey down that road.
This bracket is a little overkill but its what was laying in the garage, at least it is aluminum lol.
[Re: DemonDust]
#2180994
10/23/16 08:21 PM
10/23/16 08:21 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
On my Dana,there was no room even without the dust sheild. Bought a Strange yoke and had The Drive Shaft shop "Supershafts" shorten the drive shaft.
