Page 1 of 3 1 2 3
Racepak and 8 3/4???? Driveshaft sensor mount?? #2095836
06/21/16 08:04 PM
06/21/16 08:04 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
How did you guys mount your magnets on your yoke? I have no where to put the collar.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2095842
06/21/16 08:22 PM
06/21/16 08:22 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Call Greg here --> http://www.motorsportsinnovations.com/RacePak/racepak-sportsman.htm.
He'll know how to get You going. Buy Your system thru Him as well.
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2095845
06/21/16 08:29 PM
06/21/16 08:29 PM
Menomonee Falls
Menomonee Falls
I already have the system.
SDG Motorsports
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2095849
06/21/16 08:32 PM
06/21/16 08:32 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Hopefully He can get You going other than 'buy a 9" set-up'. up
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2095859
06/21/16 09:01 PM
06/21/16 09:01 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
On my rpm data logger I mounted mine on the 904 yoke and built a bracket that mounts on the tail housing. I have a 4 link so the yoke doesn't move too much.
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2095863
06/21/16 09:11 PM
06/21/16 09:11 PM
Menomonee Falls
Menomonee Falls
David that's a good idea. I'll measure my yoke on that end, I know I have room. Just hope they make a collar small enough to fit that yoke. I also have a 904.
SDG Motorsports
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2095886
06/21/16 09:58 PM
06/21/16 09:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had to make magnetic pickup... no one made one
for a 8 3/4. ..the pick up is mounted to the snubber
holes
wave
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2096024
06/22/16 02:03 AM
06/22/16 02:03 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
There is enough space, but you will likely have to remove the dust shield and possibly machine the yoke
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2096031
06/22/16 02:19 AM
06/22/16 02:19 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
while I'd rather have the pickup on the yoke, this set up has seemed to work ok on my 727 set up. cut an aluminum strip to make a spacer so the collar would fit tight.
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2096037
06/22/16 02:36 AM
06/22/16 02:36 AM
gregsdart Offline
gregsdart  Offline
The collar mounted on the front of the driveshaft will move a lot forward and backward on a ladderbar car, and I wouldn't even try it on a leafspring only car. If mine doesn't work where it is by the front yoke(ladderbars) I will either have to mount two rings together or weld a boss on the tail shaft and either use the parking lugs or mount a collar in there.
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2096175
06/22/16 12:16 PM
06/22/16 12:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know why your dust shield sticks out
so far but if you can push it back you will
have plenty of room.. also... if you notice
in the couple of pics that the magnets themselves
are only a 1/4" in diameter so you dont need to make
it much thicker than that
EDIT
Or do as Monte said.. trash the dust shield and slide
the magnet housing to the rear(just clear the case)
wave
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2096208
06/22/16 01:25 PM
06/22/16 01:25 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Machine the yoke if needed or it can go on the shaft itself. The Cuda was mounted on the driveshaft for years with no issue but it was a 4 link deal.
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: Al_Alguire] #2096214
06/22/16 01:41 PM
06/22/16 01:41 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Summit has different yokes available that would probably fix your issues and be stronger too.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2096384
06/22/16 07:46 PM
06/22/16 07:46 PM
Menomonee Falls
Menomonee Falls
Stronger? That's a 1350 yoke from Dr Diff.
What's weak about it?
SDG Motorsports
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2096390
06/22/16 08:11 PM
06/22/16 08:11 PM
PA.
"Little"John
"Little"John
PA.
My mistake I thought it was a stock one. My Dana has the same issue so I will be ordering one from Summit so I can mount my ring on it
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2180686
10/23/16 02:31 AM
10/23/16 02:31 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
A little late to the game on this but I thought I would add it in case it helps someone.
A little garage fab from some scrap aluminum, and a racepak collar, plus a cherry hall effect sensor and bingo, driveshaft RPM sensor. I will use this to log driveshaft speed as well as show MPH on my megasquirt.
This is a Moser yoke that I already was using, it has a nice machine 2.125 surface to mount a collar.
68 Barracuda Formula S 340
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2180755
10/23/16 10:56 AM
10/23/16 10:56 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
pretty sure that'll stay steady smile Being my trans is out, I've been eyeballing things and am ordering a smaller ring to mount on my output shaft of my 727. I'll just drill and tap the tailshaft and use a adhesive crank shaft sensor spacer. Will be cheaper and easier for me. No room on a D60 for one. I'd have to purchase a new yoke (strange U1598 for you D60 guys)
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2180963
10/23/16 07:09 PM
10/23/16 07:09 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
This will be short lived, I am putting in my spare center section since I broke two teeth off of the one you see pictured. I just bought a D60 housing to start the journey down that road.
This bracket is a little overkill but its what was laying in the garage, at least it is aluminum lol.
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2180980
10/23/16 07:58 PM
10/23/16 07:58 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
well.... at least you have a yoke part number to start your D60 project with smile
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2180994
10/23/16 08:21 PM
10/23/16 08:21 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
On my Dana,there was no room even without the dust sheild. Bought a Strange yoke and had The Drive Shaft shop "Supershafts" shorten the drive shaft.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Page 1 of 3 1 2 3
