Returning incorrect part from Hughes, what to expect? #2094601
06/19/16 08:59 PM
06/19/16 08:59 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
Hey all.
I was hoping to be installing my custom 3 bolt whiplash cam from Hughes this weekend.
Found a single bolt cam in the box as soon as I opened the end of the protective bag.
I sent Hughes an email with my issue. Tried to call in hopes there would also be voice mail, but no such luck.
So far any dealings with Hughes prior to, and during the order were all pleasant. Hopefully they can get my the correct cam without difficulties. However while pulling up return info for Hughes they seem to say they wont pay shipping on any returns. I'm hoping this doesn't include parts they shipped incorrectly. There are some interesting return stories on some other forums that popped up.
So has anyone here had to make a return for a wrong part, and how did it go, or what should I be expecting when I call Monday?
As luck would have it, today is day 10 or the disclaimer that says any discrepancies must be reported within 10 days.
I'm hoping this goes smoothly, I dont need a bunch of trouble just before I go in for surgery.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Returning incorrect part from Hughes, what to expect? [Re: hp383] #2094618
06/19/16 09:43 PM
06/19/16 09:43 PM
Central NC
gch Offline
gch  Offline
Central NC
Just call Dave or Kevin and tell them what happened.I can't say whether they will pay shipping or not but if the error was on their part I would hope they step up and take care of it.
I had an issue with a lifter failing years ago and they took care of me when they did not have to.
Re: Returning incorrect part from Hughes, what to expect? [Re: hp383] #2094890
06/20/16 11:51 AM
06/20/16 11:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You shouldn't have any problem with a return like that with Hughes. Are you sure you called the right number, they always had an answering machine/voicemail ?
Now I'll ask the dumb question , what's the need for a 3 bolt timing chain with a hyd. cam ... other than you got a smoking deal on a chain set at a swap meet that you couldn't pass up wink .. ????
Re: Returning incorrect part from Hughes, what to expect? [Re: hp383] #2094907
06/20/16 12:08 PM
06/20/16 12:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just hope there is a way you can prove you wanted
a 3 bolt... because you did say custom...and I am sure
they wont take a custom part back UNLESS you can prove
they built it wrong.... I just ordered a custom cam from
them on Friday
wave
Re: Returning incorrect part from Hughes, what to expect? [Re: hp383] #2094968
06/20/16 02:07 PM
06/20/16 02:07 PM
good ole USA
moparlifer Offline
moparlifer  Offline
good ole USA
Kevin no longer works at hughes! Took a job out of state, rumor is he sold the business?
Re: Returning incorrect part from Hughes, what to expect? [Re: hp383] #2094991
06/20/16 02:42 PM
06/20/16 02:42 PM
Central IL
70Sbird Offline
70Sbird  Offline
Central IL
Kevin is now working for Indy Cylinder Heads, His last day at Hughes was a couple of weeks ago.
Re: Returning incorrect part from Hughes, what to expect? [Re: hp383] #2094999
06/20/16 02:48 PM
06/20/16 02:48 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Just got a call from Hughes. I believe the persons name was James.
They are working on finding my camshaft. He recalled the order. since it was not typical to get a 3 bolt order on a whiplash cam designed for a stock engine. LOL
I want to build a daily driver friendly engine that sounds like a mean race motor. So the 3 bolt is to run gear drive.
Anyway. They are working hard to figure out what happened. And they are promising to fix this as soon as they can. So I am happy right now. Even if it takes a few more weeks they are fine with shipping the cam to a friend since I will be in the hospital.
Re: Returning incorrect part from Hughes, what to expect? [Re: MR_P_BODY] #2095003
06/20/16 02:49 PM
06/20/16 02:49 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
them on Friday
wave
I understand that. But luckily my invoice clearly states 3 bolt camshaft on it.
Re: Returning incorrect part from Hughes, what to expect? [Re: JohnRR] #2095012
06/20/16 02:57 PM
06/20/16 02:57 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Its to run the gear drive.
I am building a street motor that sounds like a race motor. Using mostly leftover race engine parts I had from my past 383, 440, and 451 engines.
This one is going to be a 9:1 383, with the whiplash cam, gear drive, a nicely worked set of 906 heads, and an M1 dual 4bbl tunnel ram.
I spoke with Hughes prior to ordering the cam, and per his recommendation I am using the 440 cam grind rather than the 383 cam grind since I plan to use dual 4 tunnel ram.
This is just going to be a cruise to town, Sunday driver, with the occasional trip to the 1/8 mile track for fun "run what you brung" events.
Re: Returning incorrect part from Hughes, what to expect? [Re: hp383] #2095041
06/20/16 03:40 PM
06/20/16 03:40 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
That sounds like a great build for an intimidating cruiser!!
I had to return some custom made parts for the Ramcharger once. I had 35 spline axles made by Dutchman for the Dana 60. They put 2" inch studs in the axles and I had ordered 3" on their form. The sent a UPS Call tag and picked them up, they came back a few days later with 3" long screw in studs in place. Those fit the Weld Pro Star wheels perfectly, but I ended up with CenterLine Warriors because I had measured the housing width wrong and had too much offset to clear the wheel well outer lip. It would have cut the slicks the first time they were in use. So I went to the swap section of Moparts and found a member in PA that had the right set of wheels with 5" back spacing at a good price, we made the deal and now I have more stud exposed than I need because the Warriors have a thinner center than the Pro Stars. Better too much, than not enough!!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Returning incorrect part from Hughes, what to expect? [Re: hp383] #2095238
06/20/16 09:27 PM
06/20/16 09:27 PM
Central NC
gch Offline
gch  Offline
Central NC
Sorry to hear Kevin went to the dark side.
Re: Returning incorrect part from Hughes, what to expect? [Re: hp383] #2095263
06/20/16 10:14 PM
06/20/16 10:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Glad to hear you had no problems on the return
wave
Re: Returning incorrect part from Hughes, what to expect? [Re: MR_P_BODY] #2095422
06/21/16 01:38 AM
06/21/16 01:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have bought from them a few times and I always had very good service. Glad to hear that all seems to be going well for you. Ron
Re: Returning incorrect part from Hughes, what to expect? [Re: hp383] #2095866
06/21/16 09:16 PM
06/21/16 09:16 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
They sent the call tag, and gave me a call today to let me know they are grinding a new cam, and plan to have it shipped out yet this week!
I am very satisfied.
