6.1 cam in a 5.7? #2092831
06/16/16 02:46 AM
06/16/16 02:46 AM
Pittsburgh,PA
RTSrunner Offline OP
Pittsburgh,PA
What gains can be expected from a 5.7 by adding a 6.1 cam and springs with all else remaining stock? Case in point,2004 Durango,stock exhaust,maybe some port cleanup since it is apart. Thanks,RT
Re: 6.1 cam in a 5.7? [Re: RTSrunner] #2093049
06/16/16 04:24 PM
06/16/16 04:24 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
Imo not enough for the effort...may 50hp, maybe
Re: 6.1 cam in a 5.7? [Re: RTSrunner] #2093052
06/16/16 04:33 PM
06/16/16 04:33 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Supposed to be a 25-30 hp boost. Best results are from advancing it 8 degrees from where the factory installed it (121 ICL from the factory, should put it in at 113, cam has a LSA of 117). I'd definitely put headers on it to get the most from the cam, the stock exhaust manifolds are TERRIBLE! Does that year of Durango share the same frame/platform as the similar year Grand Cherokee? If so Jeep SRT manifolds would be the way to go. You also need 6.1 exhaust springs for both intake and exhaust and 6.1 pushrods.
Re: 6.1 cam in a 5.7? [Re: RTSrunner] #2093187
06/16/16 09:21 PM
06/16/16 09:21 PM
Pittsburgh,PA
Pittsburgh,PA
Thanks for the replies.I don't think it is the same as the Jeep GC,the Durango is body on frame.Even the stock manifolds are a tight fit,and I agree,they don't even look like they flow well.Logs they are!
Re: 6.1 cam in a 5.7? [Re: RTSrunner] #2093267
06/17/16 12:10 AM
06/17/16 12:10 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
The newer Jeep SRT's with the 6.4 use a nice swoopy cast manifold that might fit (fairly cheap to). The older 6.1 Jeeps (06-10) used a shorty header from the factory that look quite compact, might be worth a try. Looks like JBA makes a header for the Hemi Durangos
Re: 6.1 cam in a 5.7? [Re: RTSrunner] #2093402
06/17/16 10:20 AM
06/17/16 10:20 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Engine swaps . com has a long tube headers for the Dakota 98 to 04. Might want to look at them.
I know your Durango is not the same platform but the hemi is a tight fit in the Dakota.
Matt
Re: 6.1 cam in a 5.7? [Re: RTSrunner] #2095467
06/21/16 07:11 AM
06/21/16 07:11 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I too have been considering this cam as an upgrade.
"I think its got a hemi"
Re: 6.1 cam in a 5.7? [Re: RTSrunner] #2100275
06/28/16 11:32 PM
06/28/16 11:32 PM
NJ, USA
Hemijoejr Offline
Hemijoejr  Offline
NJ, USA
I just put one together with a 6.1L cam. Bone stock 2006 5.7L long block, 6.1L cam installed straight up. TTI Headers, TTI 3" exhaust with dyno Max mufflers, OCP dual plane, 600cfm Holley 4160, MSD Hemi 6, 22 degrees of timing, 727 Trans, 2500 stall converter. Dynoed at 323rwhp at 5750rpm and 329ftlbs at 4000rpm.
Stock Displacement, pump gas, 5.7L Gen 3 Hemi, early 5.7L heads, 3670lbs with driver, Best time and MPH 11.11@120.9MPH
Re: 6.1 cam in a 5.7? [Re: RTSrunner] #2100399
06/29/16 02:07 AM
06/29/16 02:07 AM
Pittsburgh,PA
Pittsburgh,PA
Thanks guys.Hemijoejr,sounds like a good result with that power at the wheels.Is that powerplant for the 3670 lb. ride in your sig line?What vehicle is it in? RT
Re: 6.1 cam in a 5.7? [Re: RTSrunner] #2100436
06/29/16 09:01 AM
06/29/16 09:01 AM
NJ, USA
Hemijoejr Offline
Hemijoejr  Offline
NJ, USA
Yes, I put it in my 68 Cuda to test out the intake manifold in a super mild street carbureted combination. I only have 5 runs on it so far with a best of 13.24@104.0mph.
DA of 2214
https://youtu.be/2SO_OxKYj1M
