Re: 6.1 cam in a 5.7?
[Re: RTSrunner]
#2093267
06/17/16 12:10 AM
06/17/16 12:10 AM
Posts: 4,255 Canada
WO23Coronet
Canada
The newer Jeep SRT's with the 6.4 use a nice swoopy cast manifold that might fit (fairly cheap to). The older 6.1 Jeeps (06-10) used a shorty header from the factory that look quite compact, might be worth a try. Looks like JBA makes a header for the Hemi Durangos
[Re: RTSrunner]
#2093402
06/17/16 10:20 AM
06/17/16 10:20 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Thanks for the replies.I don't think it is the same as the Jeep GC,the Durango is body on frame.Even the stock manifolds are a tight fit,and I agree,they don't even look like they flow well.Logs they are! Engine swaps . com has a long tube headers for the Dakota 98 to 04. Might want to look at them. I know your Durango is not the same platform but the hemi is a tight fit in the Dakota. Matt
[Re: RTSrunner]
#2095467
06/21/16 07:11 AM
06/21/16 07:11 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I too have been considering this cam as an upgrade.
"I think its got a hemi"
[Re: RTSrunner]
#2100275
06/28/16 11:32 PM
06/28/16 11:32 PM
Posts: 29 NJ, USA
Hemijoejr
NJ, USA
I just put one together with a 6.1L cam. Bone stock 2006 5.7L long block, 6.1L cam installed straight up. TTI Headers, TTI 3" exhaust with dyno Max mufflers, OCP dual plane, 600cfm Holley 4160, MSD Hemi 6, 22 degrees of timing, 727 Trans, 2500 stall converter. Dynoed at 323rwhp at 5750rpm and 329ftlbs at 4000rpm.
Stock Displacement, pump gas, 5.7L Gen 3 Hemi, early 5.7L heads, 3670lbs with driver, Best time and MPH 11.11@120.9MPH
[Re: RTSrunner]
#2100436
06/29/16 09:01 AM
06/29/16 09:01 AM
Posts: 29 NJ, USA
Hemijoejr
NJ, USA
Yes, I put it in my 68 Cuda to test out the intake manifold in a super mild street carbureted combination. I only have 5 runs on it so far with a best of 13.24@104.0mph. DA of 2214 https://youtu.be/2SO_OxKYj1M
