Putting on Rons Toilet #2092331
06/15/16 10:56 AM
06/15/16 10:56 AM
Sth.IL
dare_dude Offline OP
Sth.IL
OK! trying to get a toilet system fuel system lined out. Everthing ok till I got to this point of trying to figure where to put fuel tank (no room upfront in Dart) since I had fuel cell in back decided to go with surge tank still fighting where to put it. The radiator support has been a problem because this is old race car and folks wittled on it. Friend suggested build whole new support would be ok but thats beyond my ability and would just like to get this thing fired up will think about support this winter. Anyhow decided to put surge tank up where radiator support is passenger side. Did ok rigging up bracket for it now wanting to find small radiator for drivers side for cooling and mounting it(16" x 18") Any ideas or pics of some of your guys set ups?
Re: Putting on Rons Toilet [Re: dare_dude] #2093166
06/16/16 08:30 PM
06/16/16 08:30 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
Here are some pictures of a 67 barracuda that I put an injected small block into. It has a Ron's surge tank cut into the front right hand inner fender well. The radiator is a 30" Ron Davis with electric fan and shroud fitted into the stock hole in the core support to make room for the Steff's dry sump tank. I also cut a primer tank into the left hand inner fender well. It was tight, but it all fit. I hope you can make things out in the pictures.
Re: Putting on Rons Toilet [Re: dare_dude] #2093208
06/16/16 10:14 PM
06/16/16 10:14 PM
oregon
greendart408 Offline
oregon
I don't know how to post pics here, I have ran toilets on a t/r on a sb in my dart since 08, currently run one on a single 4bbl intake, I just had a buddy fab up a 4gal cell. It fits where the batt would have been, with zero cutting.
Re: Putting on Rons Toilet [Re: dare_dude] #2093593
06/17/16 05:15 PM
06/17/16 05:15 PM
oregon
oregon
66er, how fast is that car you posted about. ??
Re: Putting on Rons Toilet [Re: greendart408] #2093723
06/17/16 09:35 PM
06/17/16 09:35 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
I don't know how fast. We are not finished with it yet. We think that it will be between 8.90 to 8.50. The engine is a 514" W-8. it dynoed at 905 hp. @ 6500 RPM. 800 ft. lb of torque @ 4900. We'll see if he can get it hooked up.
Re: Putting on Rons Toilet [Re: 66er] #2094259
06/19/16 01:15 AM
06/19/16 01:15 AM
australia
charger410 Offline
charger410  Offline
australia
I have mine under the fender. Didn't have much room under the hood
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: Putting on Rons Toilet [Re: 66er] #2146335
09/02/16 07:08 PM
09/02/16 07:08 PM
Sth.IL
Sth.IL
Did have friend rework radiator support and put cell behind right headlight bucket after bracing it in.
