Here are some pictures of a 67 barracuda that I put an injected small block into. It has a Ron's surge tank cut into the front right hand inner fender well. The radiator is a 30" Ron Davis with electric fan and shroud fitted into the stock hole in the core support to make room for the Steff's dry sump tank. I also cut a primer tank into the left hand inner fender well. It was tight, but it all fit. I hope you can make things out in the pictures.
