Re: Glide in an a body
[Re: wyldebill]
#2092638
06/15/16 07:52 PM
06/15/16 07:52 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
412 sb Duster did this swap into his yellow Duster a while back. His name is Al. Might want to check with him
[Re: Blucuda413]
#2092748
06/15/16 11:46 PM
06/15/16 11:46 PM
Posts: 1,229 In The Hills
jughed
In The Hills
I put a glide in mine years ago. It was simple and no changes to tunnel are required. Just made another mount for the existing cross member. When I later went to a JW case it got tighter in the tunnel but still no mods were required. That's good to know. I've considered a JW 'glide but worry that the car is too heavy (3300 w. me in it). Still researching, but have given the 400 a thought also.
