Re: Glide in an a body
[Re: wyldebill]
#2092638
06/15/16 07:52 PM
06/15/16 07:52 PM
Posts: 11,712 Portage,michigan
B3422W5
Portage,michigan
412 sb Duster did this swap into his yellow Duster a while back. His name is Al. Might want to check with him
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Blucuda413]
#2092748
06/15/16 11:46 PM
06/15/16 11:46 PM
Posts: 1,229 In The Hills
jughed
In The Hills
I put a glide in mine years ago. It was simple and no changes to tunnel are required. Just made another mount for the existing cross member. When I later went to a JW case it got tighter in the tunnel but still no mods were required. That's good to know. I've considered a JW 'glide but worry that the car is too heavy (3300 w. me in it). Still researching, but have given the 400 a thought also.
