4150 to 4500 #2088920
06/09/16 10:49 AM
06/09/16 10:49 AM
Alberta
Wookie316 Offline OP
Alberta
If a person is switching from a 4150 to a 4500. Where is a good starting point in regards to jetting? Same, less or more?
950 4150 to 1050 Dom is the thought here. Thanks.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: 4150 to 4500 [Re: Wookie316] #2088923
06/09/16 10:59 AM
06/09/16 10:59 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Which Dominator?
Master, again and still
Re: 4150 to 4500 [Re: Wookie316] #2088929
06/09/16 11:11 AM
06/09/16 11:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Start with the stock jetting.. watch the plugs..
they will tell you.. my 1050(gas one) was just a
few jets fatter than stock
wave
Re: 4150 to 4500 [Re: Wookie316] #2088974
06/09/16 12:23 PM
06/09/16 12:23 PM
Alberta
Alberta
That is the Dom sheet.
This is the 4150 sheet. It has a 90/98 jet in it now.
Re: 4150 to 4500 [Re: Wookie316] #2088980
06/09/16 12:28 PM
06/09/16 12:28 PM
tboomer Online work
tboomer  Online Work
Do you still have the PV in it yet?
Re: 4150 to 4500 [Re: Wookie316] #2089030
06/09/16 01:08 PM
06/09/16 01:08 PM
an8sec70cuda Offline
I'm kinda surprised by your spec sheet from Pro Systems, b/c your dominator is almost an exact copy of the dominator they built for my 572" hemi.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 4150 to 4500 [Re: an8sec70cuda] #2089042
06/09/16 01:23 PM
06/09/16 01:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
There are some basic starting points w/these things so that`s why a lot look the same or similar then you tweak from there. Either way...........to the op, it`s more than just jetting so consider the jets the first fuel restrictors and the boosters the final restrictors. The "tune" is in the emulsion, bleeds, passage sizing etc......That dom tune`s a bit wacky...........
Re: 4150 to 4500 [Re: Wookie316] #2089043
06/09/16 01:23 PM
06/09/16 01:23 PM
Alberta
Alberta
Yes the PV is still in.
That Dom was not built for my engine. It is one I have a chance to try and if it works make a deal on. To me it looks like I could try as is. It's only 2 jet sizes down from where my 4150 is now. But I'm just not sure?
Re: 4150 to 4500 [Re: Wookie316] #2089058
06/09/16 02:00 PM
06/09/16 02:00 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Stop trying to compare jet sizes on two completely different carbs; it's an apples-to-oranges thing and not a basis for evaluation of what changes may need to be made when you try the other carb.
Re: 4150 to 4500 [Re: BradH] #2089119
06/09/16 03:22 PM
06/09/16 03:22 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagree I've had around ten different Holley and severl custon built 1050 CFM Dominators, the best jet sizes ranged from 84 to 96 on them and none of them used the same sizes shock shruggy There are several other things that contribute to the fuel flow into the boosters besides the main jet sizes work
Re: 4150 to 4500 [Re: Wookie316] #2089159
06/09/16 04:29 PM
06/09/16 04:29 PM
AndyF Offline
AndyF  Offline
It appears that the Dominator is a 3 circuit carb so that is a whole different ball game.
Re: 4150 to 4500 [Re: Wookie316] #2089272
06/09/16 07:34 PM
06/09/16 07:34 PM
Alberta
Alberta
Yes I am learning that when it comes to a carb there is no 1 size fits all.
Re: 4150 to 4500 [Re: Wookie316] #2089329
06/09/16 08:55 PM
06/09/16 08:55 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Those look like Pro Systems build sheets,Call Patrick with the carb order # and specs on what you will be using it on. He will usually get you pretty close if possible. I did it with a dom that I bought from a member here and he was more than happy to help. Now have 2 of his dominators and an SV1.Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: 4150 to 4500 [Re: Wookie316] #2089638
06/10/16 02:04 PM
06/10/16 02:04 PM
Alberta
Alberta
Patrick said to try .028/.073/.046 on the bleed. No PV and a square 96 jet.
Re: 4150 to 4500 [Re: Wookie316] #2089677
06/10/16 03:23 PM
06/10/16 03:23 PM
AndyF Offline
AndyF  Offline
Could work on a drag car that leaves the line at 5000 or so and shifts at 7000 or something like. If you're trying to use it on your motor home for the summer vacation trip then it won't work worth a dang.
