4150 to 4500
#2088920
06/09/16 10:49 AM
06/09/16 10:49 AM
Posts: 326 Alberta
Wookie316
Alberta
If a person is switching from a 4150 to a 4500. Where is a good starting point in regards to jetting? Same, less or more? 950 4150 to 1050 Dom is the thought here. Thanks.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: 4150 to 4500
[Re: Wookie316]
#2088929
06/09/16 11:11 AM
06/09/16 11:11 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Start with the stock jetting.. watch the plugs.. they will tell you.. my 1050(gas one) was just a few jets fatter than stock
Re: 4150 to 4500
[Re: Wookie316]
#2089030
06/09/16 01:08 PM
06/09/16 01:08 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I'm kinda surprised by your spec sheet from Pro Systems, b/c your dominator is almost an exact copy of the dominator they built for my 572" hemi.
Re: 4150 to 4500
[Re: an8sec70cuda]
#2089042
06/09/16 01:23 PM
06/09/16 01:23 PM
Thumperdart
State of confusion
There are some basic starting points w/these things so that`s why a lot look the same or similar then you tweak from there. Either way...........to the op, it`s more than just jetting so consider the jets the first fuel restrictors and the boosters the final restrictors. The "tune" is in the emulsion, bleeds, passage sizing etc......That dom tune`s a bit wacky...........
Re: 4150 to 4500
[Re: Wookie316]
#2089043
06/09/16 01:23 PM
06/09/16 01:23 PM
Posts: 326 Alberta
Wookie316
Alberta
Yes the PV is still in. That Dom was not built for my engine. It is one I have a chance to try and if it works make a deal on. To me it looks like I could try as is. It's only 2 jet sizes down from where my 4150 is now. But I'm just not sure?
Re: 4150 to 4500
[Re: Wookie316]
#2089272
06/09/16 07:34 PM
06/09/16 07:34 PM
Posts: 326 Alberta
Wookie316
Alberta
Yes I am learning that when it comes to a carb there is no 1 size fits all.
Re: 4150 to 4500
[Re: Wookie316]
#2089329
06/09/16 08:55 PM
06/09/16 08:55 PM
Posts: 422 montana
BANDIT
montana
Those look like Pro Systems build sheets,Call Patrick with the carb order # and specs on what you will be using it on. He will usually get you pretty close if possible. I did it with a dom that I bought from a member here and he was more than happy to help. Now have 2 of his dominators and an SV1.Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
Re: 4150 to 4500
[Re: Wookie316]
#2089638
06/10/16 02:04 PM
06/10/16 02:04 PM
Posts: 326 Alberta
Wookie316
Alberta
Patrick said to try .028/.073/.046 on the bleed. No PV and a square 96 jet.
