Page 1 of 3 1 2 3
Converter fall back #2084915
06/02/16 11:28 PM
06/02/16 11:28 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
Shifting at 8400 converter falls back to 6600 is that good bad normal seems like a lot
Re: Converter fall back [Re: Plymouth340] #2084994
06/03/16 01:16 AM
06/03/16 01:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Pretty tight. Mine has been quickest when it falls back to 6300 on a 7000 shift. Really surprised me it wanted to be that loose as it has a 727 and a 15-1 572
Doug
Re: Converter fall back [Re: Plymouth340] #2085005
06/03/16 01:39 AM
06/03/16 01:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
On a SB I have done best with 1400-1500 drop.. whats
your stall and gear and tire size
wave
Re: Converter fall back [Re: Plymouth340] #2085014
06/03/16 01:43 AM
06/03/16 01:43 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Talking w/Jason Pettis the other day he likes to see between 800-1200 rpm`s BUT, not all cars fall into that category and some are quicker on either side of that.........
Re: Converter fall back [Re: Thumperdart] #2085016
06/03/16 01:50 AM
06/03/16 01:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Big block and small block are to different worlds..
BB love to use the torque.. SB have to use rpm
EDIT
But you cant ever let a SB go below the max torque
wave
Re: Converter fall back [Re: MR_P_BODY] #2085022
06/03/16 02:03 AM
06/03/16 02:03 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
He didn't specify either way..........
Re: Converter fall back [Re: Plymouth340] #2085032
06/03/16 03:05 AM
06/03/16 03:05 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
was just looking over some recordings. on my 1-2 shift we drop 1100 rpm. On the 2-3 I saw 600 rpm.
Re: Converter fall back [Re: MR_P_BODY] #2085062
06/03/16 09:05 AM
06/03/16 09:05 AM
CEDAR RAPIDS
CEDAR RAPIDS
4.88 Gears with 14x32 Tires max torque is 7000..Maybe that's why it doesn't 60 foot as it should
Re: Converter fall back [Re: Plymouth340] #2085063
06/03/16 09:05 AM
06/03/16 09:05 AM
CEDAR RAPIDS
CEDAR RAPIDS
Oh yea its a W7 small block
Re: Converter fall back [Re: Plymouth340] #2085088
06/03/16 10:38 AM
06/03/16 10:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats the stall at... and whats the race weight of
the car
wave
Re: Converter fall back [Re: MR_P_BODY] #2085092
06/03/16 10:42 AM
06/03/16 10:42 AM
CEDAR RAPIDS
CEDAR RAPIDS
the car
wave
2800 lbs..6300 stall
Re: Converter fall back [Re: Plymouth340] #2085093
06/03/16 10:45 AM
06/03/16 10:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
the car
wave
You should be running about a 7200 stall if your
peak is torque is 7000
wave
Re: Converter fall back [Re: MR_P_BODY] #2085097
06/03/16 10:51 AM
06/03/16 10:51 AM
CEDAR RAPIDS
CEDAR RAPIDS
the car
wave
wave
yeah I think it's time for a restall on the converter.. i added 200 horse and it 60 foots the same.
Re: Converter fall back [Re: Plymouth340] #2085124
06/03/16 11:38 AM
06/03/16 11:38 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
laugh2..... sounds like I'm tuning it!
what is the 60ft?
another "gray" area..... you say small block, but is it a 360ish build, or a 440? IIRC yours was a smaller cube build.
Re: Converter fall back [Re: J_BODY] #2085143
06/03/16 12:04 PM
06/03/16 12:04 PM
CEDAR RAPIDS
CEDAR RAPIDS
what is the 60ft?
1.31 60 ft..394 ci..800+ cam. My other small block with 200 less horse 60 ft just as well..I'm sure that it needs more stall
Re: Converter fall back [Re: Plymouth340] #2085151
06/03/16 12:19 PM
06/03/16 12:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
what is the 60ft?
I wish I had your cam in my W-9... I wimped.. it
was only .710... and it needed .850 to make the
heads work
wave
Re: Converter fall back [Re: MR_P_BODY] #2085161
06/03/16 12:38 PM
06/03/16 12:38 PM
CEDAR RAPIDS
CEDAR RAPIDS
The only thing I wonder about is valve spring life
Re: Converter fall back [Re: Plymouth340] #2085171
06/03/16 12:57 PM
06/03/16 12:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What carb(s).........
Re: Converter fall back [Re: Thumperdart] #2085176
06/03/16 01:01 PM
06/03/16 01:01 PM
CEDAR RAPIDS
CEDAR RAPIDS
1050 dom now but will be trying a bigger one soon
Re: Converter fall back [Re: Plymouth340] #2085181
06/03/16 01:04 PM
06/03/16 01:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You might go faster w/a properly tuned/modified 1150.........better yet two 850`s.............
Page 1 of 3 1 2 3
