Re: Converter fall back
[Re: Plymouth340]
#2085005
06/03/16 01:39 AM
06/03/16 01:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
On a SB I have done best with 1400-1500 drop.. whats your stall and gear and tire size
[Re: Plymouth340]
#2085014
06/03/16 01:43 AM
06/03/16 01:43 AM
Thumperdart
State of confusion
Talking w/Jason Pettis the other day he likes to see between 800-1200 rpm`s BUT, not all cars fall into that category and some are quicker on either side of that.........
[Re: Thumperdart]
#2085016
06/03/16 01:50 AM
06/03/16 01:50 AM
MR_P_BODY
Talking w/Jason Pettis the other day he likes to see between 800-1200 rpm`s BUT, not all cars fall into that category and some are quicker on either side of that......... Big block and small block are to different worlds.. BB love to use the torque.. SB have to use rpm EDIT But you cant ever let a SB go below the max torque
[Re: MR_P_BODY]
#2085022
06/03/16 02:03 AM
06/03/16 02:03 AM
Thumperdart
State of confusion
He didn't specify either way..........
[Re: Plymouth340]
#2085088
06/03/16 10:38 AM
06/03/16 10:38 AM
MR_P_BODY
4.88 Gears with 14x32 Tires max torque is 7000..Maybe that's why it doesn't 60 foot as it should Whats the stall at... and whats the race weight of the car
[Re: MR_P_BODY]
#2085092
06/03/16 10:42 AM
06/03/16 10:42 AM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
4.88 Gears with 14x32 Tires max torque is 7000..Maybe that's why it doesn't 60 foot as it should Whats the stall at... and whats the race weight of the car 2800 lbs..6300 stall
[Re: Plymouth340]
#2085093
06/03/16 10:45 AM
06/03/16 10:45 AM
MR_P_BODY
4.88 Gears with 14x32 Tires max torque is 7000..Maybe that's why it doesn't 60 foot as it should Whats the stall at... and whats the race weight of the car 2800 lbs..6300 stall You should be running about a 7200 stall if your peak is torque is 7000
[Re: MR_P_BODY]
#2085097
06/03/16 10:51 AM
06/03/16 10:51 AM
Plymouth340
CEDAR RAPIDS
4.88 Gears with 14x32 Tires max torque is 7000..Maybe that's why it doesn't 60 foot as it should Whats the stall at... and whats the race weight of the car 2800 lbs..6300 stall You should be running about a 7200 stall if your peak is torque is 7000 yeah I think it's time for a restall on the converter.. i added 200 horse and it 60 foots the same.
[Re: Plymouth340]
#2085124
06/03/16 11:38 AM
06/03/16 11:38 AM
Posts: 13,201 aZLiViN
J_BODY
aZLiViN
yeah I think it's time for a restall on the converter.. i added 200 horse and it 60 foots the same. ..... sounds like I'm tuning it! what is the 60ft? another "gray" area..... you say small block, but is it a 360ish build, or a 440? IIRC yours was a smaller cube build.
[Re: J_BODY]
#2085143
06/03/16 12:04 PM
06/03/16 12:04 PM
Plymouth340
CEDAR RAPIDS
yeah I think it's time for a restall on the converter.. i added 200 horse and it 60 foots the same. ..... sounds like I'm tuning it! what is the 60ft? another "gray" area..... you say small block, but is it a 360ish build, or a 440? IIRC yours was a smaller cube build. 1.31 60 ft..394 ci..800+ cam. My other small block with 200 less horse 60 ft just as well..I'm sure that it needs more stall
[Re: Plymouth340]
#2085151
06/03/16 12:19 PM
06/03/16 12:19 PM
MR_P_BODY
yeah I think it's time for a restall on the converter.. i added 200 horse and it 60 foots the same. ..... sounds like I'm tuning it! what is the 60ft? another "gray" area..... you say small block, but is it a 360ish build, or a 440? IIRC yours was a smaller cube build. 1.31 60 ft..394 ci..800+ cam. My other small block with 200 less horse 60 ft just as well..I'm sure that it needs more stall I wish I had your cam in my W-9... I wimped.. it was only .710... and it needed .850 to make the heads work
[Re: Plymouth340]
#2085181
06/03/16 01:04 PM
06/03/16 01:04 PM
Thumperdart
State of confusion
You might go faster w/a properly tuned/modified 1150.........better yet two 850`s.............
