Re: Converter fall back
[Re: Plymouth340]
#2085005
06/03/16 01:39 AM
06/03/16 01:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
On a SB I have done best with 1400-1500 drop.. whats your stall and gear and tire size
[Re: Plymouth340]
#2085014
06/03/16 01:43 AM
06/03/16 01:43 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Talking w/Jason Pettis the other day he likes to see between 800-1200 rpm`s BUT, not all cars fall into that category and some are quicker on either side of that.........
[Re: Thumperdart]
#2085016
06/03/16 01:50 AM
06/03/16 01:50 AM
MR_P_BODY
Talking w/Jason Pettis the other day he likes to see between 800-1200 rpm`s BUT, not all cars fall into that category and some are quicker on either side of that......... Big block and small block are to different worlds.. BB love to use the torque.. SB have to use rpm EDIT But you cant ever let a SB go below the max torque
[Re: MR_P_BODY]
#2085022
06/03/16 02:03 AM
06/03/16 02:03 AM
Thumperdart
State of confusion
He didn't specify either way..........
[Re: Plymouth340]
#2085088
06/03/16 10:38 AM
06/03/16 10:38 AM
MR_P_BODY
4.88 Gears with 14x32 Tires max torque is 7000..Maybe that's why it doesn't 60 foot as it should Whats the stall at... and whats the race weight of the car
[Re: MR_P_BODY]
#2085092
06/03/16 10:42 AM
06/03/16 10:42 AM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
4.88 Gears with 14x32 Tires max torque is 7000..Maybe that's why it doesn't 60 foot as it should Whats the stall at... and whats the race weight of the car 2800 lbs..6300 stall
[Re: Plymouth340]
#2085093
06/03/16 10:45 AM
06/03/16 10:45 AM
MR_P_BODY
4.88 Gears with 14x32 Tires max torque is 7000..Maybe that's why it doesn't 60 foot as it should Whats the stall at... and whats the race weight of the car 2800 lbs..6300 stall You should be running about a 7200 stall if your peak is torque is 7000
[Re: MR_P_BODY]
#2085097
06/03/16 10:51 AM
06/03/16 10:51 AM
Plymouth340
CEDAR RAPIDS
4.88 Gears with 14x32 Tires max torque is 7000..Maybe that's why it doesn't 60 foot as it should Whats the stall at... and whats the race weight of the car 2800 lbs..6300 stall You should be running about a 7200 stall if your peak is torque is 7000 yeah I think it's time for a restall on the converter.. i added 200 horse and it 60 foots the same.
[Re: Plymouth340]
#2085124
06/03/16 11:38 AM
06/03/16 11:38 AM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
yeah I think it's time for a restall on the converter.. i added 200 horse and it 60 foots the same. ..... sounds like I'm tuning it! what is the 60ft? another "gray" area..... you say small block, but is it a 360ish build, or a 440? IIRC yours was a smaller cube build.
[Re: J_BODY]
#2085143
06/03/16 12:04 PM
06/03/16 12:04 PM
Plymouth340
CEDAR RAPIDS
yeah I think it's time for a restall on the converter.. i added 200 horse and it 60 foots the same. ..... sounds like I'm tuning it! what is the 60ft? another "gray" area..... you say small block, but is it a 360ish build, or a 440? IIRC yours was a smaller cube build. 1.31 60 ft..394 ci..800+ cam. My other small block with 200 less horse 60 ft just as well..I'm sure that it needs more stall
[Re: Plymouth340]
#2085151
06/03/16 12:19 PM
06/03/16 12:19 PM
MR_P_BODY
yeah I think it's time for a restall on the converter.. i added 200 horse and it 60 foots the same. ..... sounds like I'm tuning it! what is the 60ft? another "gray" area..... you say small block, but is it a 360ish build, or a 440? IIRC yours was a smaller cube build. 1.31 60 ft..394 ci..800+ cam. My other small block with 200 less horse 60 ft just as well..I'm sure that it needs more stall I wish I had your cam in my W-9... I wimped.. it was only .710... and it needed .850 to make the heads work
[Re: Plymouth340]
#2085181
06/03/16 01:04 PM
06/03/16 01:04 PM
Thumperdart
State of confusion
You might go faster w/a properly tuned/modified 1150.........better yet two 850`s.............
[Re: Plymouth340]
#2085196
06/03/16 01:20 PM
06/03/16 01:20 PM
MR_P_BODY
1050 dom now but will be trying a bigger one soon You might be just a TOUCH low on cfm....my 405ci at 8200 rpm needed 1045 cfm...you said you shifted at 8800 so maybe a 1150 might be more in line... or a tunnel ram with a pair of slightly smaller carbs.. I sold my W-9 engine but my next step was gonna be a new cam and 2 1050s... I ran out of cam on my engine... thats why that cam you have would have helped my engine a good amount... without running it through my header program I would only guess you needed about 1080 cfm or 1100 EDIT my engine made peak torque at 6000 rpm and I ran a 5600 stall and it didnt fall back below 6000.... also I left the line right up on the conv(5600 rpm) no chip and it normally dropped to 6600-6800 rpm.... I was gonna have the conv re done to 6200 stall but didnt.. best on my junk was a 1.19 60' and 8.95 at 152.. but the 60' was normal until the side walls would start going away.. if it got down to 1.23 I got new slicks
[Re: Plymouth340]
#2085200
06/03/16 01:25 PM
06/03/16 01:25 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
That's WAY to tight...On an all out heads up NA deal we like to see 600ish on the shift. Need to keep the engine in the power band. Lugging it down but dropping that much at the shift is NOT the fast way down the track.
[Re: Thumperdart]
#2085205
06/03/16 01:33 PM
06/03/16 01:33 PM
Plymouth340
CEDAR RAPIDS
You might go faster w/a properly tuned/modified 1150.........better yet two 850`s............. yes i will find out soon on that.
[Re: Al_Alguire]
#2085207
06/03/16 01:40 PM
06/03/16 01:40 PM
Plymouth340
CEDAR RAPIDS
That's WAY to tight...On an all out heads up NA deal we like to see 600ish on the shift. Need to keep the engine in the power band. Lugging it down but dropping that much at the shift is NOT the fast way down the track. yes I'm finding that out. Car should 60-foot betterand et a lot better than it does . I'm thinking 7200 stall and bigger carb will wake this thing up..
[Re: Plymouth340]
#2085212
06/03/16 01:44 PM
06/03/16 01:44 PM
Thumperdart
State of confusion
An 1150 2-circuit will get it done............
[Re: Plymouth340]
#2085213
06/03/16 01:45 PM
06/03/16 01:45 PM
Al_Alguire
Las Vegas
You need a better converter. I mentioned this in another thread not long ago. Find a converter company who "specializes" in what you are doing. There are a few that do very well with high RPM small block stuff. My choice would be A1 but that's just me. IMO you are likely needed a good deal more stall speed and something a good deal looser for sure.
[Re: Plymouth340]
#2085228
06/03/16 01:59 PM
06/03/16 01:59 PM
MR_P_BODY
4.88 Gears with 14x32 Tires max torque is 7000..Maybe that's why it doesn't 60 foot as it should When I was running my 395ci I ran the same gear as you.. I still shifted at 8100 with the same conv that was in my 405.. that ran a best of 9.56 with a 1.24 60' still leaving on the stall.... that was with W-2 heads... that was with 14x31 slicks.. same size I have run for years now.. the 14x32 wouldnt give me enough rpms
[Re: Plymouth340]
#2085231
06/03/16 02:04 PM
06/03/16 02:04 PM
Al_Alguire
Las Vegas
The MPH is there for an 8, barely but still there. You need to work on the 330' area of the track. That's where the bulk of the ET is
[Re: Al_Alguire]
#2085239
06/03/16 02:18 PM
06/03/16 02:18 PM
Plymouth340
CEDAR RAPIDS
The MPH is there for an 8, barely but still there. You need to work on the 330' area of the track. That's where the bulk of the ET is yeah I think that's where the looser converter will really make a difference
[Re: Plymouth340]
#2085295
06/03/16 03:57 PM
06/03/16 03:57 PM
Al_Alguire
Las Vegas
So increased ability to tailor the fuel curve in a racecar is a bad thing??
The information is out there for anyone who cares to do the research. No need to pay three times as much when some research, reading and a little work will do the same thing.
Not hating just saying. IMO the debate of 2 v 3 circuit stuff is worn out. In a street car I would consider a 2 circuit deal as it will allow the end user a more user friendly format to work with. However in a race only car just don't and have not seen it. If a carb is tuned correctly for a given combo I cannot see less tenability as a good thing. A lot of the old 2v3 circuit debate goes back to the old 3 circuit carbs with the tube in the well. Poor design for sure. But that is old technology.
I also agree most guys have no use for the added stuff. Which are additional HS bleeds to further fine tune the curve. But those carbs also have intermediate jets and other advantages over the mas produced stuff out there. And yes the belong on only the best of the all out stuff out there.
[Re: Plymouth340]
#2086147
06/05/16 01:10 AM
06/05/16 01:10 AM
Al_Alguire
Las Vegas
IMO A1 for THAT application would be my first choice. I have two FTI's as well and very happy with them in bracket cars for sure.
[Re: Plymouth340]
#2088199
06/08/16 09:41 AM
06/08/16 09:41 AM
Posts: 9,997 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Ought to be interesting with the new vert, same motor, more hp, needs more stall rpm. Do you run at Eddyville? I had a lot of fun there many years ago, especially the "night of fire" Events
[Re: Plymouth340]
#2108499
07/12/16 02:45 AM
07/12/16 02:45 AM
Al_Alguire
Las Vegas
Adam and Alan are both good guys. Small high winding stuff is definitely their wheelhouse.
