360 machine pad codes
#2082148
05/29/16 02:30 AM
05/29/16 02:30 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Side of block: 10-10-73 ~ casting date 3418496-360-10 ~ casting number Machine pad (driver side below head, can't read all of it) 4W 360 1 ??503??? <- any help on this? Thanks. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) EDIT: I'm guessing 4=1974 W=Windsor 360= 360 cid Also came with the factory windage tray. Sooo I'm ASSuming HP variant?
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: 360 machine pad codes
[Re: DARTH V8Я]
#2082208
05/29/16 10:51 AM
05/29/16 10:51 AM
RapidRobert
Also came with the factory windage tray. Sooo I'm ASSuming HP variant? (1) no (2) good possibility (3) yes (4) maybe. Unrelated- some early 360 blocks were cast with 340 cores meaning they had alot of core thickness & would take more overbore than the average engine would, not that I would use that to bore one out to 60 over unless needed (CC gain from boreing is minimal) but thicker walls does give a more stable foundation especially in a perf app (if you do sonic check it you'd see it in the numbers).
[Re: Alaskan_TA]
#2082842
05/30/16 02:32 PM
05/30/16 02:32 PM
Posts: 26,000 Rio Linda, CA
John_Kunkel
Rio Linda, CA
First digit should be a letter, so a 4 is out.
With a late '73 casting date it's a '74 model year and, by then, the letter code was replaced by a single digit year code.
[Re: DARTH V8Я]
#2083139
05/30/16 11:31 PM
05/30/16 11:31 PM
DARTH V8Я
Its a TRAP!
DC says the best factory casting 360 crank is #4027169. CFD is cast into the crank. Apparently it's shot peened.
[Re: DARTH V8Я]
#2084226
06/01/16 06:55 PM
06/01/16 06:55 PM
DARTH V8Я
Its a TRAP!
Question: Isn't there supposed to be a VIN stamping on the machine pad just above the pass front pan rail?
[Re: DARTH V8Я]
#2084241
06/01/16 07:12 PM
06/01/16 07:12 PM
Posts: 2,094 central texas
krautrock
central texas
did the factory ever stamp anything on a pad front driver side of the block that comes right off of the deck of the block? i have one on my 360 and it has "DEDE" stamped in it. figure a previous owner put it there...
[Re: DARTH V8Я]
#2084475
06/02/16 03:41 AM
06/02/16 03:41 AM
Posts: 17,524 Las Vegas, NV
6bblgt
Las Vegas, NV
Question: Isn't there supposed to be a VIN stamping on the machine pad just above the pass front pan rail? early '70s trucks did not have VIN stamped drivetrain components
[Re: 6bblgt]
#2084479
06/02/16 04:06 AM
06/02/16 04:06 AM
DARTH V8Я
Its a TRAP!
Question: Isn't there supposed to be a VIN stamping on the machine pad just above the pass front pan rail? early '70s trucks did not have VIN stamped drivetrain components Did not know that, thanks. This one was out of a 1974 360 roadrunner fwiw. Guy put a 440 in it and I bought the original engine.
