360 machine pad codes #2082148
05/29/16 02:30 AM
05/29/16 02:30 AM
Its a TRAP!
DARTH V8Я Offline OP
Oh No!! I just had a moron attack!
Its a TRAP!
Side of block:
10-10-73 ~ casting date
3418496-360-10 ~ casting number
Machine pad (driver side below head, can't read all of it)
4W 360 1 ??503??? <- any help on this? Thanks. smile
EDIT:
I'm guessing
4=1974
W=Windsor
360= 360 cid
Also came with the factory windage tray. Sooo I'm ASSuming HP variant?
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: 360 machine pad codes [Re: DARTH V8Я] #2082208
05/29/16 10:51 AM
05/29/16 10:51 AM
4=1974
W=Windsor
360= 360 cid
(1) no (2) good possibility (3) yes (4) maybe. Unrelated- some early 360 blocks were cast with 340 cores meaning they had alot of core thickness & would take more overbore than the average engine would, not that I would use that to bore one out to 60 over unless needed (CC gain from boreing is minimal) but thicker walls does give a more stable foundation especially in a perf app (if you do sonic check it you'd see it in the numbers).
Re: 360 machine pad codes [Re: DARTH V8Я] #2082225
05/29/16 11:31 AM
05/29/16 11:31 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
First digit should be a letter, so a 4 is out.
Get a clear photo if you can & post it so we can see what you see.
Re: 360 machine pad codes [Re: DARTH V8Я] #2082246
05/29/16 12:10 PM
05/29/16 12:10 PM
Its a TRAP!
Its a TRAP!
Can do.
Re: 360 machine pad codes [Re: DARTH V8Я] #2082479
05/29/16 08:29 PM
05/29/16 08:29 PM
Its a TRAP!
Its a TRAP!
Dunno why pics don't show full size but here yah go:
Direct link:
http://i1224.photobucket.com/albums/ee380/ASYLUM_thirteen/20160528_224032%201_zpseqw9i8xi.jpg
Re: 360 machine pad codes [Re: Alaskan_TA] #2082842
05/30/16 02:32 PM
05/30/16 02:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
With a late '73 casting date it's a '74 model year and, by then, the letter code was replaced by a single digit year code.
Re: 360 machine pad codes [Re: DARTH V8Я] #2082843
05/30/16 02:42 PM
05/30/16 02:42 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 360 machine pad codes [Re: DARTH V8Я] #2082847
05/30/16 02:57 PM
05/30/16 02:57 PM
P
Porter67 Offline
Porter67  Offline
P
Did the timing chain look org?
Is the crank a aawj casting or cfd?
It seems to me the ones ive had or seen some of the W built motors seemed to use better quality parts although it dont make sense in some ways...
Re: 360 machine pad codes [Re: DARTH V8Я] #2082942
05/30/16 06:07 PM
05/30/16 06:07 PM
Its a TRAP!
Its a TRAP!
It's a CFD crank.
Others; thanks for the confirm thumbs
Re: 360 machine pad codes [Re: DARTH V8Я] #2083139
05/30/16 11:31 PM
05/30/16 11:31 PM
Its a TRAP!
Its a TRAP!
DC says the best factory casting 360 crank is #4027169. CFD is cast into the crank. Apparently it's shot peened.
Re: 360 machine pad codes [Re: DARTH V8Я] #2084226
06/01/16 06:55 PM
06/01/16 06:55 PM
Its a TRAP!
Its a TRAP!
Question: Isn't there supposed to be a VIN stamping on the machine pad just above the pass front pan rail?
Re: 360 machine pad codes [Re: DARTH V8Я] #2084241
06/01/16 07:12 PM
06/01/16 07:12 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
did the factory ever stamp anything on a pad front driver side of the block that comes right off of the deck of the block?
i have one on my 360 and it has "DEDE" stamped in it. figure a previous owner put it there...
Re: 360 machine pad codes [Re: DARTH V8Я] #2084475
06/02/16 03:41 AM
06/02/16 03:41 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
early '70s trucks did not have VIN stamped drivetrain components
Re: 360 machine pad codes [Re: 6bblgt] #2084479
06/02/16 04:06 AM
06/02/16 04:06 AM
Its a TRAP!
Its a TRAP!
Did not know that, thanks.
This one was out of a 1974 360 roadrunner fwiw. Guy put a 440 in it and I bought the original engine.
