Re: QUICK WILWOOD BRAKE HELP NEEDED
[Re: tsanchez]
#2076573
05/19/16 04:36 PM
05/19/16 04:36 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
[Re: tsanchez]
#2076576
05/19/16 04:38 PM
05/19/16 04:38 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I have not had good luck with vac bleeders, If you dont have a pressure bleeder then just do it the old school way, (dont pump) just press down and open bleeder, when down close bleeder and release pedal. Keep on until clear. The rears were smooth and fast but the fronts are killin me. I`m alone here and even used a painters pole on the peddle and solid bubbles. I`ll keep trying thankxxx guys.............
[Re: Thumperdart]
#2076579
05/19/16 04:41 PM
05/19/16 04:41 PM
Posts: 2,094 central texas
krautrock
central texas
can you pull the caliper and stick something in it to hold the piston in it (block of wood or clamp it or something) move caliper around so the bleeder is the low point, then bleed them... i always bleed by using vacuum hose from the bleeder to a jar and just run alot of brake fluid through the system. ^ just slowly pump the pedal from the drivers seat, make sure your MC doesn't go dry. then get out and close the bleeder snug with open end, then pull the hose off the bleeder and tighten the bleeder up tighter with the closed end.
[Re: Thumperdart]
#2076587
05/19/16 04:57 PM
05/19/16 04:57 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
^^^^^^^^^ONLY way to bleed Wilwoods right here. Get a 20 ounce Coke bottle or similar, cut hole in top and put bleeder hose through. Fill bottle about half way with fluid, crack bleeder, slip hose on and slowly stroke pedal until it stops bubbling. Quick, easy and ONLY thing I have found to work. No need to remove caliper and get bleeder low though.....Just the bottle, it WORKS
[Re: Thumperdart]
#2076608
05/19/16 05:18 PM
05/19/16 05:18 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
The problem I have run into with the Mity Vac is that sometimes you will pull in air through the threads...Glad you got it sorted!
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: MR_P_BODY]
#2076621
05/19/16 05:53 PM
05/19/16 05:53 PM
Thumperdart
State of confusion
Thankxxxx.............ended up puttin hose in jar as Monte said and used pole on brake peddle and no more bubbles but now a small leak. I`ll keep after it............ The small leak was your bubble problem to begin with.. each time you stroke the pedal its pulling in air At first Mike I just used the mighty vac w/no peddle pressure and worked great on the rears but the fronts wanted no part of it so off for a blast...........
[Re: Thumperdart]
#2076625
05/19/16 05:55 PM
05/19/16 05:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thankxxxx.............ended up puttin hose in jar as Monte said and used pole on brake peddle and no more bubbles but now a small leak. I`ll keep after it............ The small leak was your bubble problem to begin with.. each time you stroke the pedal its pulling in air At first Mike I just used the mighty vac w/no peddle pressure and worked great on the rears but the fronts wanted no part of it so off for a blast........... Where was your small leak.... also I had a front hose collapse on the inside and wouldnt bleed right.. that took me a hour to figure out... and that was with a vac set up... it would just suck the hose closed and just dribble fluid out
[Re: MR_P_BODY]
#2076635
05/19/16 06:22 PM
05/19/16 06:22 PM
Thumperdart
State of confusion
Looks like the caliper`s leaking...........so still checking....
[Re: Thumperdart]
#2076644
05/19/16 06:32 PM
05/19/16 06:32 PM
MR_P_BODY
Looks like the caliper`s leaking...........so still checking.... Well either rebuild it or replace it... it will keep sucking in air and can spin you out
[Re: MR_P_BODY]
#2076660
05/19/16 06:55 PM
05/19/16 06:55 PM
Thumperdart
State of confusion
Looks like the caliper`s leaking...........so still checking.... Well either rebuild it or replace it... it will keep sucking in air and can spin you out Exactly..............I`m done and no racing anytime soon for me till I can get it right so under the cover it goes and back to work......
[Re: Thumperdart]
#2076680
05/19/16 07:24 PM
05/19/16 07:24 PM
MR_P_BODY
Looks like the caliper`s leaking...........so still checking.... Well either rebuild it or replace it... it will keep sucking in air and can spin you out Exactly..............I`m done and no racing anytime soon for me till I can get it right so under the cover it goes and back to work...... They are easy to rebuild... once you get the parts.. it only takes minutes
[Re: FastmOp]
#2076681
05/19/16 07:24 PM
05/19/16 07:24 PM
Thumperdart
State of confusion
Which o-ring? There`s one on the piston and I assume between the body pieces. Going to get a rebuild kit from wilwood next week and go from there.............
[Re: MR_P_BODY]
#2076682
05/19/16 07:26 PM
05/19/16 07:26 PM
Thumperdart
State of confusion
Looks like the caliper`s leaking...........so still checking.... Well either rebuild it or replace it... it will keep sucking in air and can spin you out Exactly..............I`m done and no racing anytime soon for me till I can get it right so under the cover it goes and back to work...... They are easy to rebuild... once you get the parts.. it only takes minutes That`s not happening anytime soon and should be on the road now...........super pissed and I`m really loosing interest quick so done here.............
[Re: OUTLAWD]
#2076706
05/19/16 07:50 PM
05/19/16 07:50 PM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The problem I have run into with the Mity Vac is that sometimes you will pull in air through the threads... Me too. I just remove the bleeder screw and use one of the cone-shaped rubber tips that comes with the Mity-Vac shoved in the bleeder hole.
