QUICK WILWOOD BRAKE HELP NEEDED #2076568
05/19/16 04:33 PM
05/19/16 04:33 PM
State of confusion
Thumperdart Offline OP
State of confusion
Just got my rear drums under control but can`t get air out of the ft. no matter what I do. Using a mighty vac and it`s solid bubbles using top bleeder.................. shruggy Almost didn`t stop at 135 plus............ mad
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: Thumperdart] #2076571
05/19/16 04:36 PM
05/19/16 04:36 PM
Gilbert AZ
tsanchez Offline
tsanchez  Offline
Gilbert AZ
I have not had good luck with vac bleeders, If you dont have a pressure bleeder then just do it the old school way, (dont pump) just press down and open bleeder, when down close bleeder and release pedal. Keep on until clear.
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: tsanchez] #2076573
05/19/16 04:36 PM
05/19/16 04:36 PM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: tsanchez] #2076576
05/19/16 04:38 PM
05/19/16 04:38 PM
State of confusion
State of confusion
The rears were smooth and fast but the fronts are killin me. I`m alone here and even used a painters pole on the peddle and solid bubbles. I`ll keep trying thankxxx guys............. thumbs
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: Thumperdart] #2076579
05/19/16 04:41 PM
05/19/16 04:41 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
can you pull the caliper and stick something in it to hold the piston in it (block of wood or clamp it or something)
move caliper around so the bleeder is the low point, then bleed them...
i always bleed by using vacuum hose from the bleeder to a jar and just run alot of brake fluid through the system.
^ just slowly pump the pedal from the drivers seat, make sure your MC doesn't go dry. then get out and close the bleeder snug with open end, then pull the hose off the bleeder and tighten the bleeder up tighter with the closed end.
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: Thumperdart] #2076587
05/19/16 04:57 PM
05/19/16 04:57 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
^^^^^^^^^ONLY way to bleed Wilwoods right here. Get a 20 ounce Coke bottle or similar, cut hole in top and put bleeder hose through. Fill bottle about half way with fluid, crack bleeder, slip hose on and slowly stroke pedal until it stops bubbling. Quick, easy and ONLY thing I have found to work. No need to remove caliper and get bleeder low though.....Just the bottle, it WORKS
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: Monte_Smith] #2076595
05/19/16 05:04 PM
05/19/16 05:04 PM
State of confusion
State of confusion
Thankxxxx.............ended up puttin hose in jar as Monte said and used pole on brake peddle and no more bubbles but now a small leak. I`ll keep after it............ luck
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: Thumperdart] #2076608
05/19/16 05:18 PM
05/19/16 05:18 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
The problem I have run into with the Mity Vac is that sometimes you will pull in air through the threads...Glad you got it sorted!
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: Thumperdart] #2076615
05/19/16 05:30 PM
05/19/16 05:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The small leak was your bubble problem to begin with..
each time you stroke the pedal its pulling in air
wave
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: Thumperdart] #2076617
05/19/16 05:39 PM
05/19/16 05:39 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Those willwood bleeders are easy to mess up, I keep some around just in case.
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: MR_P_BODY] #2076621
05/19/16 05:53 PM
05/19/16 05:53 PM
State of confusion
State of confusion
wave
At first Mike I just used the mighty vac w/no peddle pressure and worked great on the rears but the fronts wanted no part of it so off for a blast........... thumbs
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: Thumperdart] #2076625
05/19/16 05:55 PM
05/19/16 05:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
Where was your small leak.... also I had a front hose
collapse on the inside and wouldnt bleed right.. that
took me a hour to figure out... and that was with a vac
set up... it would just suck the hose closed and just
dribble fluid out
wave
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: MR_P_BODY] #2076635
05/19/16 06:22 PM
05/19/16 06:22 PM
State of confusion
State of confusion
Looks like the caliper`s leaking...........so still checking....
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: Thumperdart] #2076644
05/19/16 06:32 PM
05/19/16 06:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well either rebuild it or replace it... it will keep
sucking in air and can spin you out
wave
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: MR_P_BODY] #2076660
05/19/16 06:55 PM
05/19/16 06:55 PM
State of confusion
State of confusion
wave
Exactly..............I`m done and no racing anytime soon for me till I can get it right so under the cover it goes and back to work......
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: Thumperdart] #2076673
05/19/16 07:14 PM
05/19/16 07:14 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
It's just an O ring
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: Thumperdart] #2076680
05/19/16 07:24 PM
05/19/16 07:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
They are easy to rebuild... once you get the parts..
it only takes minutes
wave
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: FastmOp] #2076681
05/19/16 07:24 PM
05/19/16 07:24 PM
State of confusion
State of confusion
Which o-ring? There`s one on the piston and I assume between the body pieces. Going to get a rebuild kit from wilwood next week and go from there.............
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: MR_P_BODY] #2076682
05/19/16 07:26 PM
05/19/16 07:26 PM
State of confusion
State of confusion
wave
wave
That`s not happening anytime soon and should be on the road now...........super pissed and I`m really loosing interest quick so done here............. drinking
Re: QUICK WILWOOD BRAKE HELP NEEDED [Re: OUTLAWD] #2076706
05/19/16 07:50 PM
05/19/16 07:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Me too. I just remove the bleeder screw and use one of the cone-shaped rubber tips that comes with the Mity-Vac shoved in the bleeder hole.
