BB Superchargers. Any fit? #2070893
05/10/16 05:36 PM
05/10/16 05:36 PM
SC
V194 Offline OP
V194  Offline OP
SC
Any BB superchargers of any manufacturer fit underhood? Baring the procharger type or Paxton type. Anything else?
Re: BB Superchargers. Any fit? [Re: V194] #2070917
05/10/16 06:26 PM
05/10/16 06:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Underhood of what?
Pretty sure nothing Roots based will fit, unless it's in a truck of some sort and even then.
Don't be the exception.
Re: BB Superchargers. Any fit? [Re: Supercuda] #2070961
05/10/16 07:30 PM
05/10/16 07:30 PM
SC
V194 Offline OP
V194  Offline OP
SC
Originally Posted By Supercuda
Underhood of what?
B, E or C bodies.
Re: BB Superchargers. Any fit? [Re: V194] #2070983
05/10/16 08:02 PM
05/10/16 08:02 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
No roots or screw type blowers will fit under the hood of a 60s-70s car when mounted on a V8.
You can probably fabricate some sort of valley cover and intake to use with an EFI system but you're on your own.
A blower under the hood will have to be centrifugal.
Personally, I prefer turbos. biggrin
- Stu Harmon
Re: BB Superchargers. Any fit? [Re: V194] #2071002
05/10/16 08:25 PM
05/10/16 08:25 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You might have room under the hood of a C body to remote or front mount a roots type and duct the output thru a normal carb/intake setup. But that'd be "interesting" to say the least
Re: BB Superchargers. Any fit? [Re: V194] #2071040
05/10/16 09:34 PM
05/10/16 09:34 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
49 Desoto maybe.
Kevin
Re: BB Superchargers. Any fit? [Re: feets] #2071073
05/10/16 10:05 PM
05/10/16 10:05 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
There was a company in Australia that was building a whipple style top mount kit for the 426 Hemi... with a low profile air cleaner it fit under the hood of a Challenger at least (the main test car they used)
There were various issues with the setup though and it never really went any where...
Re: BB Superchargers. Any fit? [Re: V194] #2071327
05/11/16 10:19 AM
05/11/16 10:19 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I made this for a 67 coronet I had. The "kit" was for a BB Chevy, I adapter the main bracket and had the crank pulley drilled out for a BB Mopar. At the time (and as far as I know now) a Mopar kit was like 4k. This cost me $2200 including carb prep, gauges, and fuel system upgrades.
Coming soon!!!!
Re: BB Superchargers. Any fit? [Re: Mr.Yuck] #2071341
05/11/16 10:34 AM
05/11/16 10:34 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Re: BB Superchargers. Any fit? [Re: Supercuda] #2071372
05/11/16 11:45 AM
05/11/16 11:45 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
NO.... a small 471 would fit under a hood with a small scoop however it is pretty small for a 440.
Re: BB Superchargers. Any fit? [Re: V194] #2071519
05/11/16 04:16 PM
05/11/16 04:16 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Maybe with some K-frame spacers.
Re: BB Superchargers. Any fit? [Re: bobby66] #2071535
05/11/16 04:44 PM
05/11/16 04:44 PM
I'm strickly WAG ing here but the post reminded me of the "Magnacharger" supercharger kits of decades ago (iirc hood clearance was its bennie that was touted in addition to unGodly airflow/power output. It come out sideways on eac side as opposed to straight up like a Roots & dipped down and had 2 side draft? Dellorto carbs (also iirc). If I was to do one at first blush I'd go with the Paxton like what was pictured but I would definitely get familiar with the supercharged sites to gain some knowledge as I'm a newer than new newbie. I remember a quote in Hot Rod decades ago stating "that you are not ready for the power"
Re: BB Superchargers. Any fit? [Re: V194] #2071553
05/11/16 05:14 PM
05/11/16 05:14 PM
SC
V194 Offline OP
V194  Offline OP
SC
Why I asked about "other than" kits was that from what I can see there is little room for A/C and PS with a Procharger type system. Now I have checked the supercharger store and IMO they are way out there on pricing. All of the Magnacharger types I see today are from late model HEMI only?
So if you have a big block (440+) and want to make some decent power (700+ HP) and have it reliable and live on the street we can go turbo or supercharger. I cant see any other way to get to the HP goal. Thoughts?
Re: BB Superchargers. Any fit? [Re: V194] #2071592
05/11/16 06:33 PM
05/11/16 06:33 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Nitrous grin
A Kenne-Bell or Whipple would be nice if someone made an intake for a 440.
Re: BB Superchargers. Any fit? [Re: V194] #2071941
05/12/16 10:29 AM
05/12/16 10:29 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Buy a kit for a BB Chevy and modify it. That will save you thousands. You can relocate your alternator and use a small GM unit. I ditched my PS unit and but my battery in the trunk. You would want to mount it in the passenger side. One thing you also might want to do is ditch the big-old factory ac compressor and go with a small modern unit. That will free up a bunch of space.
Re: BB Superchargers. Any fit? [Re: Mr.Yuck] #2072146
05/12/16 05:55 PM
05/12/16 05:55 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I don't normally think of the words "Roots Supercharger" and "reliable and live on the street" all in the same sentence. I certainly get the desire for horsepower thing though.
I’m listening.
